Old 11-03-2019, 04:21 PM   #1
White halftrack
1978 Chevrolet Blazer picked up.
Yesterday I picked up the blazer that I had posted about before. The weather was perfect and If I didn’t grab it now would probably be sitting there until spring. Put a set of ralley wheels on it and probably like those better than the wagon wheels. Cleaned out the interior a bit and ripped off the running boards. Looks much better now. Should make a nice truck. Not quite sure what I will do with it but it was too nice of a truck to leave out for someone to strip parts off of. It is now lubed up and in a building out of the weather.
White halftrack is offline   Reply With Quote
Old 11-03-2019, 04:25 PM   #2
White halftrack
As found pic. Also included a pic of another truck at the yard.
Old 11-03-2019, 09:24 PM   #3
White halftrack
Questions
As you can see my tailgate latch is missing. I can see that I can find the bolt on latch but I don’t have the core. I have the keys to the ignition and doors but can a core for the latch be located with my key number? On the latches I see on eBay I don’t see how they engage the pawl that cranks up the window. Maybe I am missing something.
Any help appreciated.
Old 11-04-2019, 08:28 AM   #4
Re: 1978 Chevrolet Blazer picked up.
Blazer looks good. I moved this to the Blazer area so you would have a better chance at getting an answer.
Old 11-04-2019, 08:46 AM   #5
v30crewcab
v30crewcab's Avatar
just have to get one rekeyed to your key. lmc has diagrams that might show how it all works.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 11-04-2019, 01:26 PM   #6
1976gmc20
Does it run?
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 11-04-2019, 03:06 PM   #7
White halftrack
Originally Posted by 1976gmc20 View Post
Does it run?
No. It is not stuck but has been sitting a long time. Poured stuff down engine and will look at again in a couple weeks. A pretty original machine. Still has the factory am radio. Has not been messed with.
Old 11-06-2019, 11:08 AM   #8
engineer_gregh
engineer_gregh's Avatar
Locdoc might be able to help you with re-keying a new rear window crank.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 11-07-2019, 02:36 AM   #9
68Timber
I know the pieces fit
68Timber's Avatar
LMC does have a diagram. With the window crank removed from the gate the key tumbler can be removed and re-keyed by your local locksmith. I bought a new tumbler for the crank on my 79 and had this done.
Edit to add, interesting truck - I don't think I've ever seen that color combo before. Congrats on the purchase and I look forward to seeing it running.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
