11-04-2019, 07:32 PM | #1 |
C60 C10 part interchange information.
Does anyone know if the column from a c60 will swap to a c10?
There are no c10s local that have a factory column but we have a big truck salvage yard with about 10 of these. Been looking for odds and ends with great luck but unsure if im reqdy to pull the trigger on one that im not sure will fit. Factory blinker complete steering column with decent steering wheel for 100 bucks is rare around these parts. Any info would help i am willing to modify it as long as it looks stock in the cab. Thanks in advance Thomas |
11-04-2019, 10:42 PM | #2 |
Re: C60 C10 part interchange information.
I’m fairly sure the steering wheel is a larger diameter. As for the shaft being the same length and diameter I don’t know. Might try posting in the heavy hauler section.
11-04-2019, 11:17 PM | #3 |
Thanks bud will do.
11-05-2019, 12:49 AM | #4 |
60-66 Nut
No the C60 steering column will not work in a C10,20 or 30. In the C50,60 and 80 trucks, the steering column is attached directly to the steering box.
