fix for speedometer reading wrong due to new 700r4
any help, installed a 700r4 transmission in my 64 c10...speedometer seems a little off now..feels like i'm going 65mph and speedometer showing 100mph..
heard that i need to get the gears changed on the speedometer cable...how can i figure this out and where do i search to get the correct gear? |
Re: fix for speedometer reading wrong due to new 700r4
You can find gears here:
https://www.rockauto.com/en/catalog/...ive+gear,11676 https://www.summitracing.com/search/...ion-type/700r4 short how to: http://www.73-87.com/7387garage/drivetrain/spdgears.htm calculator here: https://www.tciauto.com/speedometer-gear-calculator Also, if you have a smart phone, you can download a GPS speedometer app and verify accuracy.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
![]() Join Date: Jan 2011
Here is what you need to know. Tire height, rear end ratio and the color of the drive gear in the transmission. Then you can go to tone of the gear calculator pages and find out what driven gear you need. You may find that the drive gear will not work for your setup and have to change it. I have linked TCI's page below and they have a list of available drive gear options for you trans listed. You can try drive gears with more or less teeth till you find a set that works for your truck.
Jimmy https://www.tciauto.com/speedometer-gear-calculator
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
