Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-07-2019, 07:00 PM   #1
redsled87
redsled87's Avatar
87 R10 Suspension crossmember
I'm sure this has been asked before. Has anyone modified their stock front suspension crossmember for weight savings. This is in a drag truck that sees a lot of track use and some street use. It doesn't haul anything any more. I know they are heavy and I would like to lighten it up. I was thinking of cutting the middle out and putting some tubing to replace it. I don't need a drop member for it. I want to keep the stock a arms since I just rebuilt everything recently. I know there are some places that make all new stuff but, for $4,000 I can build a lot of horsepower.
Thanks!
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 11-08-2019, 09:13 AM   #2
regan wilson
regan wilson's Avatar
Re: 87 R10 Suspension crossmember
There really isn't much weight to save in the crossmember. My old one was cut up for oil pan clearance. There is more weight savings to be had in steering, control arms, brakes and spindles.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 11-08-2019, 09:18 AM   #3
regan wilson
My old setup I adapted a rack and pinion to. I also sent my spindles to Strange and they built brakes for it. If I remember correctly one spindle, with rotor and caliper weighed 70 lbs. When they came back from Strange the whole box weighed 69 lbs.
Old 11-08-2019, 09:53 AM   #4
71Dragtruck
71Dragtruck's Avatar
Another thing to think about, yes for $4000 you can build power, but you still have all that weight on the nose and it won't transfer weight and hook up as good at shaving 175lbs off the front, and adding power will only make lack of traction worse.
Unless you are launching soft and then gradually bringing on a ****load of power, and that can be a dangerous game losing traction on the big end.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 11-08-2019, 10:15 AM   #5
regan wilson
Redsled you should look at 71Dragtruck's front suspension. It would be money well spent.
Old 11-08-2019, 10:30 AM   #6
Ziegelsteinfaust
I have modified a few cross members for a drop, but what it you set it up in a jig. Cut the portion out between the frame rails, and weld in a 2x4 1/8 wall piece of steel. Then gingerly finish plating in the new section. This may save around 20 pounds. As when I sectioned the crossmember I had about 5 pounds of metal cut out.
Ziegelsteinfaust is offline   Reply With Quote
Old 11-08-2019, 11:14 AM   #7
redsled87
redsled87's Avatar
Thanks for the replies. I was starting to think that also. I was looking at the wilwood modular spindles and brakes too. I don't know how much weight that would drop.
60' 1.49
1/4 10.93
MPH 120
Old 11-08-2019, 11:18 AM   #8
redsled87
redsled87's Avatar
71Dragtruck what front enddo you have?
60' 1.49
1/4 10.93
MPH 120
Old 11-08-2019, 12:21 PM   #9
71Dragtruck
I have a Scott's in mine, since I got mine others have come onto the market, I might have went different if doing it now, if pretty much a strip truck, things you will want no matter the brand, coil overs, no sway bar, manual rack and pinion, mustang 2 spindles and brakes, lot's of light options to be had.
Be for warned that no matter the brand a BBC with off the shelf headers the steering rod to the rack is a real treat to route, do yourself a favor off the hop and if not running motor plates do it, even then be ready to scratch your head LOL.
Here is a thread with most details of my truck, look through for the scott's install, hopefully this is a week where PB actually works.
http://67-72chevytrucks.com/vboard/s...d.php?t=783776
Sponsored by:
Hard Candy Customs
Old 11-11-2019, 02:21 PM   #10
tinydb84
tinydb84's Avatar
If you don't mind running ford stuff there was a guy on the ls1tech forums who sectioned a Crown Vic IFS to fit his truck. You can probably find it under his name "truckdoug" but he also has a few pictures on his instragram "littlevictoryfabco"
David
Instagram: myfabguy
Old 12-12-2019, 10:06 AM   #11
77c10bowtie
77c10bowtie's Avatar
ive seen alot of aftermarket stuff like control arms, spindles and brakes are heavier than factory stuff, mostly due to being bigger to increase performance and strength and provide rigidity. what kinda stuff is out there with the drag racer in mind.
are there any decent off the shelf manual rack kits or is it a diy only, my issue with a diy racks is it usually adds in bumpsteer.
with budget in mind what are some decent control arms that dont add weight, from what ive seen most tubular are heavier than stock.
same with brakes, decent brakes that are lighter that don't break the bank, don't need ridiculous stopping power just enough to be safe and effective.
77 SWB 2wd. gutted, caged, slicks, not weighed yet
02 Duramax CCSB 4x4 12.7@104 6750lbs
77c10bowtie is offline   Reply With Quote
Old 12-16-2019, 08:31 AM   #12
PGSigns
PGSigns's Avatar
Look at Nolimit.net for a rack and the front cross member that they have. Give Rob a call and see what they have that will get you where you want to go.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
