Old 11-16-2019, 11:41 AM   #1
HTX86chevy
HTX86chevy's Avatar
03 Denali DBW question
I pulled a 6.0/4l60e from a Denali that is AWD with red and blue ECU connections. This Denali is DBW.
I swapped the transmission for a 2wd 4l60e
I’m looking for a harness with Red and blue connections for ECU that would be DBW but only finding DBC available.
Am I stuck reworking my own harness?
HTX86chevy is offline   Reply With Quote
Old 11-16-2019, 12:17 PM   #2
ls1nova71
ls1nova71's Avatar
Re: 03 Denali DBW question
I think you must have the year wrong. The blue and red harnesses stopped in 2002, so it is most likely a 2000-02. They use a different TAC and throttle body than the 03-07. So if you try looking for a harness for a DBW 2002 truck you should find it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-16-2019, 12:36 PM   #3
HTX86chevy
HTX86chevy's Avatar
Heading to the shop later today. I’ll double check the year. Thank you.
Old 11-16-2019, 04:00 PM   #4
ls1nova71
ls1nova71's Avatar
A 2000-2002 will have a 2 plug throttle body and an all plastic TAC, that's the easiest way to tell.
Old 11-17-2019, 02:50 AM   #5
HTX86chevy
HTX86chevy's Avatar
Turns out it’s a 2001 . Thanks you.
