Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 11-17-2019, 01:09 PM   #1
ecbert
Spicer 16244 Axle
Anyone know where I could find a Spicer 16244 rear axle for my GMC 5500? Looking for one with 10 hole bud wheels with GM's famous 8 3/4" bolt pattern, not Daytons.
2018 Silverado 6.2 1500 Crew Cab
2011 12 Passenger G3500
1969 369 Nova
1967 Chevelle SS 396
1970 GMC 5500
1991 V3500 Single RR Wheel Gen 6 496 / 4L80E
ecbert is offline   Reply With Quote
Old 11-17-2019, 01:45 PM   #2
sweetk30
sweetk30's Avatar
Re: Spicer 16244 Axle
i got a rear from a 82 c-60 with 10 lug bolt pattern . single speed axle . removed for a 4x4 swap . not sure condition of brakes but was driven in to shop before swap . i got the front also even tho its just a drop beam 2wd axle .
only problem maybe is i am in upstate new york .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-17-2019, 03:56 PM   #3
ecbert
Can you snap me a couple of pictures? Im curious as to what style it is, also I can arrange for freight shipping if you're willing to drop it off on a pallet...
1969 369 Nova
1970 GMC 5500
Old 11-17-2019, 07:19 PM   #4
sweetk30
sweetk30's Avatar
see what i can do for pics .
i got yellow-roadway / abf / and few smaller in my area . zip is 14901 for the terminals . i got a few BIG skids or worst case can make one .
Old 11-18-2019, 05:28 PM   #5
txagincali
I've got a rear axle off of an 1988 GMC Topkick which I am pretty sure is the same axle setup you are looking for. I cut the frame off in front and behind the spring perches so it is all one unit if interested. I was going to use it for my C50 swap but am going 8 lug instead.
Oh and it has hydraulic disc brakes on there as well. I'll try and grab some pics for ya.
1963 Olson Grumman Bread Van - Possible Suburban Swap (sporadically worked on to strip paint)
1969 GMC C10 Pickup SWB Stepside (heart transplant)
1969 Chevy C50 Fire Truck converted to Utility Truck being built into Pickup Truck (newest addition, accumulating spare parts)
1972 GMC K5 Blazer 4x4 (sporadically being worked on, accumulating parts)
txagincali is offline   Reply With Quote
Old 11-18-2019, 05:52 PM   #6
txagincali
Well I lied, its actually an Eaton Axle and not a Spicer. Same frame width on my 69 C50 Frame as it was from this 88 Topkick though if that helps broaden your search.
Old 11-18-2019, 11:24 PM   #7
ecbert
Eaton / Spicer are they not one and the same? So you say the frame width is the same?!? What is the outside to outside on the tires? How about spring perch to spring perch? I'll bet your wheels are not the GM 10 lug on 8 3/4 BCD, they look like a wider pattern...
1969 369 Nova
1970 GMC 5500
