11-21-2019, 02:03 AM | #1 |
Roto Reuter thats the name...
Power Steering Pump fitment probs on LM7 5.3 K10 swap
I'm in the process of swapping a 5.3L LM7 into my 1970 K10. I was planning to use the stock 5.3 PS pump and stock PS/Alt accessory bracket. I'm having a problem with fitment of the PS pump. The low pressure line hits on the frame. Anyone else have interference problems with the PS pump? I don't really want to try to bend that line in fear of damage. I'm wondering if there is a different style pump that would work with the stock accessory bracket. Any help would be appreciated.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
11-21-2019, 04:10 AM | #2 |
Post Whore
Re: Power Steering Pump fitment probs on LM7 5.3 K10 swap
are you referring to the return line?..got a pic?..trying to picture in my mind where its hitting
what engine mounts are you using? maybe you could raise the engine up some...
11-21-2019, 10:00 AM | #3 |
I just carefully bent mine, but my engine may be in a different position than yours, so it may not have been as close.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
11-21-2019, 05:00 PM | #4 |
So I tried to bend it a bit. I can't really go any more. As it is my line will be coming out right behind the PS pulley.
I bent this line and only have about 1/8" clearance from frame. When engine is running it will probably still hit. The line is now directly behind where pulley will go.
11-21-2019, 05:16 PM | #5 |
Post Whore
I bent mine to point out a little...but mine is about 2in above the frame rail
11-21-2019, 07:07 PM | #6 |
Hey Dan, I messaged mine to make a tighter curve off the pump. I have about a good inch clearance from the frame. My motor is pretty solid and I don't think it will ever move enough to hit. I also rotated the curve to point more to the fender to avoid the pully. I will try and get a picture but may be this weekend before I get it.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
11-21-2019, 07:59 PM | #7 | |
11-21-2019, 09:09 PM | #8 |
can you not bend it down so its down between the frame its just rubber return hose
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
11-21-2019, 10:03 PM | #9 |
Dave, I thought about doing this. I may still try. I really like the idea of having the line between the frame anyway. I'll let you know if I try it.
11-23-2019, 09:28 PM | #10 |
I decided to bend the PS pump line down so it would fit between the frame rails. Should be good now.
11-23-2019, 10:12 PM | #11 |
Post Whore
That should work..!
11-24-2019, 11:28 AM | #12 |
Sorry dan I have been working and haven’t got a chance to get to my shop for a pitcture.
Looks that in the rail looks fine. My motor might sit higher then yours since my line is above the rail.
