11-27-2019, 11:36 AM | #1 |
FI and new engine
I purchased a Pro Flo 4 kit a while back. I got it all installed with a new engine. I just have to prime the oiling system and then make sure the distributor is installed correctly. I did make sure there were no leaks in the fuel lines, so I'm good there as the fuel pump was whining as it ran to pump gas through the lines. The gauge showed 58psi, perfect! I'm honestly a little scared to start it though....
11-27-2019, 03:17 PM | #2 |
Re: FI and new engine
Sounds like some excitement is about to happen.
11-27-2019, 04:06 PM | #3 |
Well yes. I'm just nervous about getting the distributor set correctly. I did as the fuel injection instructions said and set it 12 degrees BTDC. Still, I'm concerned that I might screw it up. Any advice for double checking that I'm on the correct stroke?
11-27-2019, 08:50 PM | #4 |
set it for the tdc mark, pull number one spark plug and see if you can blow compressed air into the cylinder and have it hold or if it leaks out past the valves. be careful doing this as it tends to rotate the engine if you pressure it up too much. it is basically a cyl leak down test. otherwise, pull a valve cover, watch the rockers as you rotate the engine, and deal with leaky gasket after.
11-27-2019, 08:58 PM | #5 |
if you just want to test fire it, disable the fuel pump, squirt a little gas down the intake, install the air filter again in case it pops back through the intake when you try to start it. now crank it over and see if it tries to start or if it pops back. if it tries to start then it is probably set up ok for tdc on "ready to fire" stroke. if confident that is the case then connect the fuel pump and try it again, it'll probably fire up. install a timing light and adjust timing to be close enough to break it in. follow the recommended break in procedure from the manufacturer of the engine and document as req for warranty purposes.
