11-29-2019, 10:26 AM | #1 |
Old member
How to...
What is used to put the windows back together on the tracks for the driver & passenger side windows? I need to get the parts together so I can have them ready for door assembly next week I hope.
What does one use to put the glass in the metal holder to assemble it?I have all the window rubber and felts.
11-29-2019, 10:45 AM | #2 | |
The Older Generation
Re: How to...
It always used to be glass setting tape. It is a special tape that has cork and rubber with a cloth mesh bonded together. You can get it at glass shops. It comes in different thicknesses. Some people use a butyl rubber sealant but I tried that and it was hard to keep the glass centered and vertical. If a guy used a couple of small strips of the glass setting tape at the front and back edges to keep the glass centered it would probably work Ok. Here is a video I found that shows the tape. There may be better ones but this is the first one I found. https://www.youtube.com/watch?v=5uZao9rxCLA LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-29-2019 at 10:53 AM. |
11-29-2019, 12:26 PM | #3 |
Re: How to...
I took mine down to a glass shop and they did it for $30 let them keep them for a few days and done,I didn't want to chance it being off or glass breaking =harder than you think
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
11-29-2019, 01:02 PM | #4 |
Re: How to...
I got some of the glass setting tape (don't recall where), and did it myself. I set the glass upside down on some rubber pads and used a rubber mallet to gently tap them on, with good luck, just went slowly. The hardest part was figuring out the exact alignment so it slides back into the door.
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
11-29-2019, 01:09 PM | #5 | |
Re: How to...
I have some windows out if anyone needs measurements on the position of the channel. LockDoc
11-29-2019, 01:10 PM | #6 |
Moderator
Re: How to...
Truck and car shop sells three different thicknesses of the glass setting tape, that’s where I got mine. I don’t recall the thickness I used though
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
11-29-2019, 08:54 PM | #7 | |
Old member
Re: How to...
Can you get the measurements for me please sir. Just in case. I guess I'll call my buddy at the body shop and see what he suggest's.
11-30-2019, 08:18 AM | #8 |
Re: How to...
I have a couple sets of side window/runners as well. I can measure those to see what variance, if any, is allowable
11-30-2019, 01:10 PM | #9 |
Re: How to...
As for how to assemble...
I did this operation on one side of my truck years ago. I bought the rubber tape from one of the many online suppliers - I forgot which one. My dad, the retired after 40+ years at the St. Paul Ford Assembly plant was at my house. I showed him the pieces and asked if he knew how the pieces go together. He asked for a hunk of 2x4. He took the pieces off the concrete we were standing on into my lawn. He draped the rubber over the glass, placed the channel over the rubber, and whacked the track with the 2x4.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
11-30-2019, 03:27 PM | #10 |
Re: How to...
I just put glass back into the sash last weekend. I found this diagram in the assembly manual. Says the sash should 0.73 or about 3/4 inch forward from the back edge of the glass.
In my case the glass came out of the sash but the setting tape was still in the sash. I used some sealant as a “lube” and glued the glass back into the original tape on the sash. It was tight fit and required using a rubber mallet. So far so good.
1972 GMC K2500 Super Custom Matt |
11-30-2019, 10:19 PM | #11 |
Re: How to...
Just got back home and measured mine. Mine measure 5/8 inch from the edge of the glass on both ends. LockDoc
12-01-2019, 03:36 PM | #12 |
Old member
Re: How to...
I ordered new regulators and so now I need to try and get the glass mounted I guess. Thanks Doc for the measurement. Dang I wished I thought to measure the one that was still together before i pulled it a part. The drivers side just came a part on it's own.
Fbks_Cruiser thanks for the picture. I'll have to pull mine out I guess.Use for reference.
12-04-2019, 08:26 PM | #13 | |
Old member
Re: How to...
Everybody I talked to locally said either use 3M Auto Glass Urethane Windshield Adhesive are rubber paper that you order off the internet. I figured a inner tube is just as good and it was free. I don't think it will need any kind of glue but I figured I ask the experts. After I got it set in place with the straps I took the vise and made sure the channel was tight to the glass. So what do you say.
12-04-2019, 09:30 PM | #14 | |
Re: How to...
Looks like that should work. The rubber paper he was referring to would be the glass setting tape we have been talking about. It doesn't really have any paper in it, it is cork and some kind of cloth or fiber mesh. After you trim the rubber down I think I would still run a small bead of the urethane along that edge inside and out. LockDoc
12-04-2019, 09:45 PM | #15 | |
Old member
Re: How to...
