12-11-2019, 12:28 AM | #1 |
Alternative way --Fender Emblems
So I installed the emblems on the fenders or should I say attempted too but I cannot get all three screws in and the rattle was bad, i know there's a few creative people on here, did any of you use 3m tape or emblem glue or something the bolt closes to the doors is virtually impossible to install with the fenders on the truck , just looking for other ideas....
Thanks |
12-11-2019, 10:54 AM | #2 |
Re: Alternative way --Fender Emblems
Just curious, what year? Never had any issue with a 58-9
Allen |
12-11-2019, 11:05 AM | #3 |
its a 55 2nd series there is one screw that is too high up on the fender and there is just no way to tighten down and if you don't tighten it , the emblem rattles so I was wonder if anyone has your any type of fender tape or other ways to mount them
12-11-2019, 01:01 PM | #4 |
if I was going to use tape it would be VHB 3m (very high bond). I used it on 60-66 side trim instead of drilling 100 holes and multiple high pressure car washes it didnt budge. it is what car manufacturers use to attach the rub strips and emblems on new cars. you can get it in any hardware store although its pretty thick there, the thin stuff I get at the craft store like hobby lobby. you get one shot at sticking it! so make sure the surfaces are clean clean clean, and make a temp jig from popsicle sticks or something to make sure it goes exactly where you want it.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
12-11-2019, 01:12 PM | #5 |
3m adhesive?
12-11-2019, 01:50 PM | #6 |
i painted mine on...
we use 3m double sided tape for all sorts of body mods use the grey 300mph stuff, not the white
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
12-11-2019, 10:51 PM | #7 | |
On 1955 the side emblems are BELOW the belt line. There shouldn't be much issue tightening the nut with the door open. I don't have a '56 but their emblems are two piece and above the belt line. If you have stock emblems in good condition I wouldn't use tape because you'd have to remove the studs on the back of the emblems.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
12-12-2019, 10:25 AM | #8 |
door open? Sorry I don't understand bud. Theres no access if the door is open, where the front fender and body connect you can't even slide you hand in there let alone a socket wrench. I may have to wait till paint when the fender come off.
I like the idea of 3m may have to stack a few pieces may two bolt and 3m tape on ends? Painted one looks great! |
12-12-2019, 01:13 PM | #9 |
Having same problem on 54 AD. The "push nuts" and crappy chinese metal studs keep coming loose. Going to find some good 3m tape and stick em on and use better "push nuts" as insurance.
12-20-2019, 08:20 PM | #10 |
Couldn't find 3m at store but they had 30# Gorilla brand double back tape. Stuff absolutely did not stick on clean surfaces and just trying to peel off the backing was a nightmare. Stuff is cr-p and Gorilla company ghosted me big time when i complained. Done with them.
12-21-2019, 01:51 AM | #11 | |
https://www.homedepot.com/p/3M-Scotc...C-SF/203405976
12-21-2019, 02:16 AM | #12 |
Post Whore
Also at parts stores that have a decent auto body section usually carry the 3M tape as well..
12-21-2019, 05:10 AM | #13 |
Just be sure its ok for the temps the truck will be in, I tried to use some gorilla glue for something in the car ,was holding good till summer when it hit 100*glue just melted.
12-21-2019, 08:17 AM | #14 | |
good tip and a valid concern. I will say that 99% of all new cars on the road use VHB to install their emblems and the door rub strips, even the little trunk spoilers or other accessories. its strong as hell, the product page I linked says items up to 20 lbs. I used it on a camera mount that went on the fender. looked impossible especially with that camera body out in the wind but it stuck
12-21-2019, 01:25 PM | #15 |
we use a lot of the 3m tape on body kits and window louver kits
use the 3m adhesive promoter for anything you want to stay attached works well with stick-on velcro too, trash bag in my dd has been stuck on my dash since 09 amazon.com/3M-Adhesion-Promoter-Sponge-
04-08-2020, 09:50 AM | #16 |
I bought the $7 stem and press washer kit from truck shop and it works brilliantly , problem
solved |
