Old 12-19-2019, 01:06 PM   #1
rod1701
rod1701's Avatar
Troubleshoot dual tanks
While I’ve got the bed off, I need to fix my dual tank switch.
Done some reading that solenoid can be a failure point on these. But need a process for troubleshooting to see if it is switch, solenoid, or other.
Doesn’t help that gas gauge isn’t working and will need to test the sending units for both.
Any steps to help me narrow down the problem area without throwing a ton of uneceddary parts and $$$ at it?
1979 C-10 LWB
rod1701 is offline   Reply With Quote
Old 12-19-2019, 01:47 PM   #2
HO455
Post Whore
HO455's Avatar
Re: Troubleshoot dual tanks
A quick search for "dual tank problems" revealed this thread. I hope it helps.
http://67-72chevytrucks.com/vboard/s...d.php?t=754061
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 12-19-2019, 02:52 PM   #3
Moved your post to the truck section instead of blazer area. You will probably get more response that way.
Old 12-19-2019, 03:46 PM   #4
rod1701
rod1701's Avatar
Thanks.
1979 C-10 LWB
