New '59 Apache owner
Hi All
Bought myself this "virgin". Supposedly a '59 Apache. Can anyone tell me what I bought please? VIN: M53846 Engine: F602JA 53846 (Engine size????) As far as I can tell 99.9% original, 3-sp manual, RHD.
Best regards, Philip Chev: '70 C10 (350 V8 / 700R4 ) & '59 Apache ( 235, 3-sp ) Jensen Interceptor '74: Mopar 440(EFI'ed) / 4L60e Jaguar: '72 E-type Coupe V12 & '74 E-type V12 Convertible & '80 XJS V12 |
Re: New '59 Apache owner
try this. they are usually pretty quick with a reply.
https://www.gmheritagecenter.com/gm-...tion-kits.html |
Someone asked what is mounted between the wipers....
This truck was built in South Africa. Do you think that shield was made here?
![]() ![]() Join Date: Nov 2008
Beautiful truck, though that visor looks unusual. Maybe because it's a So. African truck the visor was sourced from who-knows-where?
My dad's '59 long Fleetside was exactly this color but he didn't paint the rims red. Too bad, they look excellent. His was a 235, then I "helped" him put a 283 in it (I was a little kid, mostly I got in the way) and finally a 348. Rans like a stung cat. Good memories.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
![]() Join Date: Mar 2009
The visor looks like the type that was used on late 1940's-early 1950's cars and trucks, a popular brand was Fulton and I believe they were made in the US. I've never seen one with a center support though, that could be a SA thing. Nice looking truck!
1962 Chevy blue SBFS 1957 Chevy yellow SBSS 1956 GMC red SBSS Nov 2017 ToTM https://www.facebook.com/groups/Cana...geChevyTrucks/ |
The VIN format is different what was used in USA and Canada. Canada was different from USA also. Do you have any pictures of the engine?
Here's a link to a very detailed installation of Jag front and rear suspension in a 59
http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Here's the engine.
#9 | |
Looks like a 235 by the thriftmaster sticker but I believe that is a 261 air cleaner. Interesting that nothing seems to be moved under the hood to accommodate the right hand drive except the column of course. I expected to see the battery on the other side lol.
Here's a link to a ton of info about your truck which you can download and save https://www.gmheritagecenter.com/doc...olet-Truck.pdf
1962 Chevy blue SBFS 1957 Chevy yellow SBSS 1956 GMC red SBSS Nov 2017 ToTM https://www.facebook.com/groups/Cana...geChevyTrucks/ Last edited by bobinbc; 01-17-2020 at 03:11 AM. |
if you want a power brake up grade kit, contact master power brakes -
mpbrakes.com. im using one of their kits in my '49 AD & its great |
#12 | |
Where the shield is mounted to the roof, there is a large stainless steel washer with these words stamped : Sterling Sun shields Durban So, it seems these sun shields were manufactured locally in those years...
#13 |
I would not put too much faith into that sticker. How can I positively ID what engine I have?
#14 |
there is a machined pad on the side of the engine near the distributor that has some numbers on it. here is a link to a site with the same problem as you and how they found the engine size.
https://www.stovebolt.com/ubbthreads...ification.html |
#15 | |
Does this "F602JA" type number look familiar at all?
#16 |
#17 | |
This last link was the breakthrough because it showes the exact location of where the casting no is: Against the block, below the vacuum advance (nothing to do with the machined area behind the distributor as most sites mentioned). So, my engine has the casting no 3764476 which makes it a 235 ![]()
#18 |
OK wait!!!!! the steering column is on the right????
#19 |
Right!!
#20 |
Nice shape, wow.
Good work on digging through to find the engine size. |
