01-17-2020, 01:42 PM | #1 |
Seat Riser Questions
Does anyone have a good measurement on the seat riser? I need side-to-side at the front, and the rear. Also, is the riser centered or off to one side?
Thanks! |
01-17-2020, 02:03 PM | #2 |
Post Whore
Re: Seat Riser Questions
Mine is 48-5/8 in the front ,and 52-5/8 in the back...and its centered
01-17-2020, 02:24 PM | #3 |
Thanks!
01-18-2020, 11:20 AM | #4 |
How much clearance is there between the adjustment handle (on the driver's side) and the door. Mine seems to hang out over the rocker for some reason....
01-19-2020, 10:27 PM | #5 |
I think the one in my 51 cab (parts donor) still has the adjustment handle in it. Too dark now but if my brain remembers it tomorrow I'll get you some measurements and photos.
01-20-2020, 12:20 AM | #6 |
Post Whore
Mine sticks out past the rocker 3/4"...and it's about a inch away from the door panel
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 01-20-2020 at 06:49 PM. |
01-20-2020, 04:41 PM | #7 |
Here are some shots that I took a few minutes ago. I didn't realize that they had beat spot that the seat track bolted to up that much until I went out to take the photos. Probably from pounding their shoulder against the door to open it as the window molding is smashed pretty bad on the drivers side. That rather than lubing or repairing what made it stick.
01-20-2020, 04:58 PM | #8 |
A few more plus today's view out back with the mountains hidden behind the clouds.
if you need specific measurements or shots I can get them ..
01-20-2020, 05:29 PM | #9 |
EXCELLENT! Thanks, and nice shot of what the land looks like around there....
About the only measurement I need now is from the back of the track to the top of the rib (stiffener) that goes across the cab (the back of the riser), basically - where the two holes for the track are... |
01-20-2020, 08:15 PM | #10 |
The back of the slide track is about 1/4 inch above the level of the cross brace so the seat frame can clear the cross brace.
The one without the tracks is back in the shed behind some stuff that makes it hard to reach to accurately measure.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 01-20-2020 at 08:23 PM. |
01-20-2020, 08:31 PM | #11 |
That should do it! Thanks for digging!
01-22-2020, 01:35 PM | #12 |
i will have to look closer at mine. there is an adjustment handle.. not sure it is attached to anything.
01-22-2020, 01:39 PM | #13 |
A lot of the time the wire going across to the track on the other side to pull the release is broken or gone and you can only wiggle the driver's side but not move the seat.
