01-26-2020, 04:24 PM | #1 |
Head Gasket Material?
Copper or fiber? 1953 235 pretty much stock.
01-26-2020, 06:48 PM | #2 |
Re: Head Gasket Material?
Unless you are building it to race and are seriously concerned about the compression ratio I'd say Felpro blue or equivalent.
I have used steel shim or copper gaskets in the past but you want the head and deck to be perfectly true and you have to use something for a sealant on the gasket. Lots of choices in that dept depending on who you talk to also. On the other hand I have never had head gasket issues while using a high quality fiber gasket like the blue FelPro ones. They are a bit more forgiving if you head isn't exactly perfectly true and seal well.
