Old 01-29-2020, 11:55 PM   #1
'65 chevy lover
Aux Vacuum pump to assist brakes on '65 C10
The motor in my truck doesn't make enough vacuum because of the cam in it, and the brakes don't work near as well as I'd like them too. I've looked around a little bit, but can't seem to find much anything that would show me what I need to make a good auxiliary vacuum pump system. If anyone here knows about this I'd appreciate the help.
Thanks,
'65 chevy lover is offline   Reply With Quote
Old 01-30-2020, 01:17 AM   #2
slepysal
slepysal's Avatar
Re: Aux Vacuum pump to assist brakes on '65 C10
Have you consider using a Hydroboost system?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 01-30-2020, 08:40 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Or a vacuum pump: https://67-72chevytrucks.com/vboard/...74#post8668474
Old 01-30-2020, 09:09 AM   #4
nsb29
nsb29's Avatar
Hydro boost!! put a vacuum pump On a friends El Camino extremely noisy even over the loud exhaust
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 01-30-2020, 09:16 AM   #5
MikeN
MikeN's Avatar
X2 - I put an electric vacuum pump on my Chevelle many years ago due to a radical camshaft, and HATED it - crazy loud, even over loud mufflers. Took it off and threw it away after less than a week. Hydroboost is expensive, but really the only way to go.
MikeN is offline   Reply With Quote
Old 01-30-2020, 10:18 AM   #6
88Stanger
88Stanger's Avatar
Recently i went through this exact issue on my "69 C10. I tried two types of power boosters, no good. Then i tried a vacuum reservoir again to no fix. So, lets try a vacuum pump. Expensive, extremely loud, and well did not really fix the problem to my satisfaction. So, what now? Well hydro boost here i come. Let me just say that there is a very quite vacuum pump out there, very expensive, but really quite. I decided to take on the Hydro boost. What a great way to get solid, strong brakes. I am hooked. I now have a vacuum pump that is for sale.
PS If you go with Hydro boost, get with CaptFab on here! He has brackets that are just top notch and perfectly constructed.
Good luck with what every way you go.
88Stanger is offline   Reply With Quote
Old 01-30-2020, 01:09 PM   #7
'65 chevy lover
Never heard of a Hydroboost system, but I'll do some diggin on it. Thanks for the help!
Old 01-30-2020, 01:32 PM   #8
'65 chevy lover
Old 01-30-2020, 01:38 PM   #9
'65 chevy lover
Thanks to all for the help!
Old 01-30-2020, 08:10 PM   #10
nsb29
nsb29's Avatar
Hydro boost runs off your power steering pump I got mine from the local u pull
Old 01-31-2020, 02:36 AM   #11
slepysal
slepysal's Avatar
Mr.search is your friend
http://67-72chevytrucks.com/vboard/s...ferrerid=28772
Old 01-31-2020, 09:06 AM   #12
LT1 Burb
LT1 Burb's Avatar
I put a big cam in my convertible and used a hydroboost system, it has no problems with vacuum.
LT1 Burb is offline   Reply With Quote
Old 01-31-2020, 09:10 AM   #13
LT1 Burb
LT1 Burb's Avatar
better pic of it.
Old 01-31-2020, 09:43 AM   #14
kensblue64
Thanks,
I had a simliar problem with several cammed motors.
There is an easy and economical solution.
A vacuum Reservoir or commonly called a vacuum reverve canister
They are cheap, easy to install, and effective.
Easy install Just run the vacuum hose from your intake manifold to the tank, and then run a hose from the tank to your power brake booster. That's it.
Go for a ride, apply the brakes several times, and smile.
Here is a link to an install
https://www.youtube.com/watch?v=0OMIzCvYefY
The canister is about $40.00 at Jegs or Sumitt, and the best thing, is that there are no mechanical, hydraulic, or electrical parts to fail, or wear out.
kensblue64 is offline   Reply With Quote
Old 01-31-2020, 10:37 AM   #15
64shortbox
64shortbox's Avatar
Another thought - If you can find it is in the late 70's early 80's GM ran vacuum pumps on some of the Cadillac's & Chevy's, the diesel Olds etc. They mounted the vacuum pumps under the battery tray to help absorb vibration & noise. Since they did use them on Caddys I would think they would have to be fairly quiet but finding a late 70's Caddy might be difficult now.
64shortbox is offline   Reply With Quote
Old 01-31-2020, 01:07 PM   #16
MikeN
MikeN's Avatar
Another possibility - my 2017 Chevy Suburban has a belt driven vacuum pump for the brakes. There's one big serpentine belt for all the other accessories, and a small, separate belt that drives only the vacuum pump.
https://www.amazon.com/ACDelco-12669.../dp/B01E6FWW1Y
You would have to fab a mounting bracket, probably put a different pulley on it for a v-belt, etc. But it is silent.
Old 01-31-2020, 08:26 PM   #17
'65 chevy lover
Thanks to all for your replies. Now I just have to decide what to get.
Old 01-31-2020, 10:44 PM   #18
Captainfab
60-66 Nut
If you decide to go with a hydroboost, here is what I offer to make it a bolt on deal.
http://www.67-72chevytrucks.com/vboa...d.php?t=339081
http://www.67-72chevytrucks.com/vboa...d.php?t=347480
Old 02-01-2020, 04:07 AM   #19
'65 chevy lover
Thanks, Captain, will do!
Old 02-01-2020, 11:50 PM   #20
Cohi
Cohi's Avatar
i installed a LEED brake bandit to resolve my issue with this. Its a rotary pump and quiet. A little pricey, but it works well.
Denver/Big Island -- Instagram: Slammed66c10
'46 Fleetmaster Coupe
'64 C10 on Ridetech Air Ride
'66 C10 on GSI Bagged Chassis - in progress
'12 FLHR
'11 Custom Homebuilt Chop/Softail
Cohi is offline   Reply With Quote
Old 02-02-2020, 06:34 PM   #21
'65 chevy lover
Thanks for the reply! What I get will depend on price. I need to get cheap, but good!...LOL The Leed pumps looked good, but I'm kinda thinking about one of the motor powered, maybe hydroboost, or a pulley powered pump. I'll just have to weigh it all out.
