02-01-2020, 07:44 PM | #1 |
Front grill assembly
I will be installing my grill , splash guard and top bar . On my 68 GMC
Is there any order that this all get put togeather . I am guessing top bar first , grill and then splash guard ? Advice appreciated Thanks |
02-03-2020, 12:29 PM | #2 |
Re: Front grill assembly
I would assemble the top bar to the grill, install the grill, then the splash guard. Usually the top bar is riveted to the grill so that's why I would do it that way.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
02-03-2020, 07:58 PM | #3 |
That’s the order I put them in , how ever I installed the grill with out pop rivets , I think that was a stupid GM idea. I used u clip nuts , I put them on the top bar and used #8 SS screws to mount the grill to the top bar . It worked out great . Then I can remove the grill any time I choose with out dealing with pop rivets.
02-04-2020, 02:14 PM | #4 |
Yeap, the rivets are a pain.
Good luck, Rg
