Old 02-05-2020, 02:05 AM   #1
raylube
raylube's Avatar
63 to 66 k10,k20 rear upper shock mounting bolt and hardware picture request.
My 64 k20 was missing rear shocks and upper rear shock hardware. Can only find 60-62 pictures in assy manual. Looking to make or fab some new ones. Any pictures or part numbers. THANKS
raylube is offline   Reply With Quote
Old 02-05-2020, 07:10 AM   #2
evan396
Re: 63 to 66 k10,k20 rear upper shock mounting bolt and hardware picture request.
Pics of our 66 k20 rear shocksName:  20200205_060658.jpg
evan396 is offline   Reply With Quote
Old 02-05-2020, 12:07 PM   #3
raylube
raylube's Avatar
Thanks for the pics. Is there a sleeve or tube between the frame and bracket with a bolt in the center or is it just one bolt? What is the size of the bolt and shock bushing? What shocks are you using? I am swapping in a 14 bolt and will also need to weld shock mounts to the axle. Thanks
Old 02-05-2020, 05:43 PM   #4
jdl71
jdl71's Avatar
x2 on what kind of shocks. I havent been able to find any with a 3/4" bore
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 02-05-2020, 06:41 PM   #5
72cs20
I'm in the same boat here. The solution I like is to sleeve the shock mounts and use an easily available shock with whatever size bolts they come with. Finding shocks that use that giant factory bolt could be a pain in the neck.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 02-05-2020, 07:01 PM   #6
evan396
They are rancho shocks. Rs5143 with 3/4" bushings. There are two steel bushings in between the frame and the shock mount, they are 3/4x1"5/8 each. The bolt is 3/4x6 1/2 long and travels through the whole shock mount. We also changed to a 14 bolt ff and have the weld on shock mounts. Jdl71, I don't know if this will help you if you still have the Eaton rear end still in the truck. But it might close enough. Name:  20200205_174233.jpg
Old 02-05-2020, 11:39 PM   #7
raylube
raylube's Avatar
Thanks, now I know what to look for. However I will need to try and find a 6 inch longer shock due to my lift.
Old 02-06-2020, 01:08 AM   #8
'63GENIII
'63GENIII's Avatar
Originally Posted by evan396 View Post
Thats a pretty slick idea for squaring up and holding the rear spring packs there Evan. Wish I would have thought of that when I did mine.
Is that a late model 14B with factory disc?
Nice looking work!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 02-06-2020, 01:20 AM   #9
'63GENIII
'63GENIII's Avatar
Late model springs and flipped? Looks nice. I can't see it in the pic but is your upper shock mount blending in or has it been removed?
Chris
'63 k15 long step
Old 02-06-2020, 07:14 AM   #10
evan396
Hey chris, that's an older 80s 14 bolt ff. Drums and brakes were shot. After pricing out new brake drums and hardware we decided to go with the lugnut 4x4 brake conversion. Those are the stock springs and we had all four reworked at the local spring shop and they are sitting in the stock spring hangers. You can see in the pictures that they still have the factory rivets in them. We are in the process of rebuilding the rockwell t211 transfer case and when we get that done we can install it and get the pinion angle set and weld it all up. The brace helped keep everything lined up and square when we centered the axle.
Old 02-06-2020, 10:47 AM   #11
raylube
raylube's Avatar
Here's some pictures of shock mount and other stuff. Here is what I started with .http://67-72chevytrucks.com/vboard/s...d.php?t=768418
Old 02-06-2020, 07:47 PM   #12
jdl71
jdl71's Avatar
They are rancho shocks. Rs5143 with 3/4" bushings. There are two steel bushings in between the frame and the shock mount, they are 3/4x1"5/8 each. The bolt is 3/4x6 1/2 long and travels through the whole shock mount. We also changed to a 14 bolt ff and have the weld on shock mounts. Jdl71, I don't know if this will help you if you still have the Eaton rear end still in the truck. But it might close enough. Attachment 1980282
Attachment 1980283
Thanks. Its a good place to start at least. The shock mount on my Eaton looks pretty much like the one you are showing in the pic.
Psalm 23
64 C10
66 K20
Old 02-07-2020, 12:58 PM   #13
raylube
raylube's Avatar
Evan, tell me about that lower shock mount that you have.
Old 02-07-2020, 07:46 PM   #14
evan396
EbayName:  Screenshot_20200207-184425_eBay.jpg
Old 02-17-2020, 09:59 PM   #15
jdl71
jdl71's Avatar
Bilstien makes some apparently also. 19.1 mm = .7519 inches:
https://www.desertrat.com/series-215...%7Cyear%3D1966
Psalm 23
64 C10
66 K20
