02-24-2020, 11:56 PM | #1 |
Bad Gas is the Main Suspect
So as a few of you know, I picked up my uncle's '77 K10 a couple weeks ago. Now, he hadn't driven it in like 5 years but it had been maintained/run from time to time by a distant cousin of mine.
It's a dual tank setup. Before departing on my 200 mile trip home, I went to get some gas. The left tank was full but the right tank was almost empty (switch in cab was on right tank). I ran 3 tanks of gas on the right tank and she ran like a top. As the right tank was almost empty,I flipped the switch to the left tank. It ran for 2 days just fine. Today, I was headed to work and the truck abruptly shut off on the highway. I couldn't get it started. A similar situation happened years ago in my old 71...It was the HEI coil gave out. I figured it was the same problem but it was not. I also replaced the Ignition Control Module but that wasn't it either. Carb was starved for fuel. I changed out the fuel filter (that looked pretty good) and got her running again but she stalled 3 more times on the way home. I did switch back to the right side tank and fill it up before changing fuel filter. Now, she idles rough and I think I may have jarred the kickdown cable as she won't shift out of 1st without going to L2 then back to D. It's probably a couple of small issues to get her right again. What would y'all consider a good checklist to make sure I get all this corrected?
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland www.YouTube.com/user/593Films - Watch My Videos! 1977 Silverado K10 2014 Dodge Durango (Wife-mobile) 2008 Dodge Ram Lone Star Edition (Daily driver) |
02-25-2020, 12:18 AM | #2 |
Post Whore
Re: Bad Gas is the Main Suspect
I'd pull tanks and clean them,,,blow out all fuel lines, replace all filters and hope the carb isnt full of crap...if it is I'd rebuild it
02-25-2020, 08:10 AM | #3 |
May have been a reason the cab switch was on the nearly empty right tank. If there was, no telling how old that stuff in the left tank really is.
Could be as simple as the hose(s) from the tank to the frame and switch valve being bad and letting air into the system. Age or mice can cause a bad hose. Put a gas filter on the suction side of the fuel pump(Fram G3 or equiv) until you are sure the fuel system is clean. A lot easier to check/change that one then the one in the carb. Transmission fluid level correct? If it sat for five years, one of the seals might be bad and it is now low on fluid. If fluid correct, I would also drop the transmission pan and replace the filter and inspect the old fluid and filter for debris. |
02-25-2020, 08:56 AM | #4 |
I would replace all the rubber lines while you are in there.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
02-25-2020, 09:26 AM | #5 |
I would also check the vacuum line going to the vacuum modular on the transmission. Maybe you knocked it of the intake when you were working on distributor. That would make it run rough and not shift correctly.
02-25-2020, 07:53 PM | #6 | |
Truck running and shifting like a top now!
