03-03-2020, 09:21 PM | #1 |
250 inline 6 trans swap
I have a Muncie 21 4 speed and I want better fuel economy/lower rpm during highway speeds I heard a t5 will bolt right up but I didn't know if that was my only manual transmission option if a 5 died is the best I can do I will but this is my daily driver and I plan on keeping it for the next 50 years of it's life 1970 C20
03-03-2020, 09:51 PM | #2 | |
Re: 250 inline 6 trans swap
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by LockDoc; 03-04-2020 at 10:14 AM. Reason: Not a FS thread |
03-03-2020, 09:56 PM | #3 |
here is one of those threads
http://67-72chevytrucks.com/vboard/s...d.php?t=173219 and yet another http://67-72chevytrucks.com/vboard/s...d.php?t=557179 Iwas going to do this many moons ago and bailed on it because of many of the reasons in these threads good luck if you decide to go forward it can be done and has been done
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 03-03-2020 at 10:01 PM. Reason: more |
03-03-2020, 11:09 PM | #4 |
You were going to switch to a 5 speed? What stopped you?
Last edited by LockDoc; 03-04-2020 at 10:12 AM. Reason: Removed FS You need to be a Premium member to sell stuff on here |
03-03-2020, 11:11 PM | #5 |
Btw those are talking about a 350 I got a 250 inline in my truck
03-04-2020, 12:25 AM | #6 |
it wont hold up
I BELIEVE IN JOHN 3:16 |
03-04-2020, 02:29 AM | #7 |
Location: Herculaneum MO (20 minutes south of St. Louis
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
03-04-2020, 08:24 AM | #8 |
Get a donor trans from a 4.3 should be great on your 4.1. You will be thrilled with how much better it drives. An M21 is a terrible choice for an L6 powered truck so the 5 speed will do everything better. The M21 with it’s 2.54 first gear is completely lacking compared to the 3:1 or so the 3 speed would have had.
03-04-2020, 10:17 AM | #9 |
The Older Generation
^ I agree. I have an S10 five speed in my Green '67 with a 250 I6 and it works great, and made it a lot more enjoyable to drive.
LockDoc
03-04-2020, 03:40 PM | #10 |
Did you use the hydraulic clutch or were you able to keep the mechanical set up?
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
03-04-2020, 07:23 PM | #11 | |
I kept the mechanical. Unfortunately I didn't do a write up on it. I purchased the spacer plate and used the '85 Astro van 11" clutch disk. I didn't have to use the adapter ring in the bell housing locator hole, it was the right size for the S-10 front bearing retainer. Here is where the shifter is in relation to the bench seat. I bent the shift lever straight up from where the sharp bend was and it worked pretty good. It isn't as close to the dash as it looks. The shifter on it now is off of a full size pickup 5 speed and it is too big to screw on the shaft and too long. I just slid it down over the shift lever so I could test drive it. The yellow circle shows where the original shifter hole was and the new hole is about 8-1/4" back. The shift tower on some of the 5 speeds is a lot farther back. LockDoc
03-05-2020, 03:23 AM | #12 | |
http://67-72chevytrucks.com/vboard/s...2&postcount=14
Best regards, Philip Chev: '70 C10 (350 V8 / 700R4 ) & '59 Apache ( 235, 3-sp ) Jensen Interceptor '74: Mopar 440(EFI'ed) / 4L60e Jaguar: '72 E-type Coupe V12 & '74 E-type V12 Convertible & '80 XJS V12 |
03-05-2020, 11:46 AM | #13 | |
03-05-2020, 07:29 PM | #14 |
Will having a C20 make any difference when it comes to a S10 trans it will that be too much strain on it
03-05-2020, 09:05 PM | #15 |
You can break anything if you work at it, but you are not in any real danger with the inline 6.
03-05-2020, 10:53 PM | #16 | |
I can't tell you how much heaver the c20 is than a C10 but I can't see it making much difference. Mine is a C20. LockDoc
03-06-2020, 03:42 AM | #17 |
I seem to recall seeing somewhere that the difference was about 400 pounds
03-06-2020, 07:43 PM | #18 |
I'm worried though that if I get a t5 from a S10 which is a lot lighter than a full size truck it'll be too much strain
03-07-2020, 12:26 AM | #19 | |
I would wait and find something you would feel comfortable with then. LockDoc
03-08-2020, 09:16 AM | #20 |
An S-10 pulling a 2500# trailer is would be a way heavier combination than your truck.
Get an S10 trans and swap it in. You will be thrilled. Fuel injection has made modern cars reliable and adjustment free, but overdrive transmissions are what makes new cars so driveable in all conditions at all speeds. You will be thrilled.
03-09-2020, 06:26 PM | #21 |
I found a T5 off a 00 S10 2.2l would I need an adapter to fit it in my truck or will it even work at all
03-09-2020, 08:18 PM | #22 |
I think the 2.2 has the 60 deg bellhousing. You really want one from a 4.3 so it will all bolt on.
