03-13-2020, 02:40 PM | #1 |
Carrier Bearing....?
I am cleaning/rebuilding the driveshafts from my 47.5 3600. I have them apart and the "carrier bearing" is pretty much crystalized. It's the (formerly...) rubber type (or okem..?). I need a replacement. Where is a good place to get one, and what are they calling it?
03-13-2020, 04:13 PM | #2 |
Re: Carrier Bearing....?
usually they are just called the center support bearing. napa? it's just a bearing inside a rubber donut really.
03-13-2020, 08:51 PM | #3 |
03-13-2020, 10:09 PM | #4 |
check this out from the stovebolt forum
https://www.stovebolt.com/ubbthreads...&Number=641131 https://www.pbase.com/dennygraham/driveline&page=all |
03-13-2020, 11:53 PM | #5 |
The filling station shows both the bearing (it has to have a bearing) and the support cushion that you are asking about.
https://www.parts123.com/parts123/yb...Z5Z5Z50000014x One reason you aren't finding it is that is not a "carrier" bearing (those go inside the rear axle) it is a center support bearing.
03-14-2020, 04:25 AM | #6 | |
03-21-2020, 11:28 PM | #7 |
!/2 ton closed drive shaft? or 3/4 ton open drive shaft. I had it in my mind that you had a 3/4 ton.
If you have a 1/2 ton closed driveshaft you need an "oakie" bushing. that is only for closed drive trucks though. https://www.parts123.com/parts123/yb...rt~A2~cadefefx
03-22-2020, 09:09 AM | #8 |
It is a 3/4 ton....The front half is enclosed, the rear one is open. I need the rubber one you posted earlier...
