03-23-2020, 01:06 PM | #1 |
Replacement swing out towing mirror heads or glass and seal
When I was younger you could buy replacement mirror glass a seals for the mirrors on our suburban. Does anyone know where to source a set of replacements? Glass/seals or mirror heads?
Thanks in advance.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
03-24-2020, 07:16 PM | #2 |
Re: Replacement swing out towing mirror heads or glass and seal
The silvering was getting bad on the mirrors on Dad's 77. We had a local glass shop cut some replacement mirror glass and I installed them into the mirror heads. I was able to carefully remove and re-use the existing seals (they were still in good shape) so I'm not sure what's currently available (if anything) for replacement seals.
03-29-2020, 01:51 PM | #3 |
I would try GM dealer, old glass shop. If not then your going to have to look replacement mirror that may have good looking seals but bad chrome or glass, or good mirrors. Oh I do think the seals are the same swing out towing mirror style on you truck Ford, GM, Aftermarket, 70% on the Dodge.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
03-29-2020, 08:23 PM | #4 |
They are available from Autozone. Part # Burco 2204. Maybe less from a glass shop.
03-31-2020, 05:03 PM | #5 |
These look like they will work. Cant find any gaskets... doh, they are on the same site...
04-01-2020, 11:20 AM | #6 |
glass shops usually can get all that
