03-23-2020, 10:01 PM | #1 |
Edelbrock carb - period correct?
Hey guys,
I have a 1972 Chevy K20 that was not running right when I bough it last year, so I bought a new Edelbrock carb to get it going. The truck is fairly original, and I want to keep it mostly original and period correct to the early 70s. So my question is, were Edelbrock carbs around and being used on our trucks at that time? Or did they not come out until later, like in the 80s? Thanks!
'68 Chevy K20 '72 Chevy K20 - Smokin' Ochre '08 Mercury Grand Marquis - Daily driver/ Parts fetcher Ohh uh, I didn't have time to fix everything... |
03-23-2020, 10:12 PM | #2 |
Re: Edelbrock carb - period correct?
Kind of. The Edelbrock is nothing but a Carter AFB which was around. It was in the 90's that Edelbrock branded carbs showed up. But they Carter/Edelbrock would not have been found on a GM of that era. The mid 60's would have been the last of the AFB's.
Your truck would have had a Quadrajet on it, and no carb is better than a good Q-jet for a daily driver.
03-23-2020, 11:58 PM | #3 |
Factory period correct No.
Mopar was big on the AFB. Even though Ford, and Chevy both used them to some extent. I have a Ford AFB avs laying around somewhere in plan to put one bastard Hot Rod I have to finish up. Period correct for Hot Rods yes. Although not as in vogue in the late 60' as the Holley they still were out in force. I would run just run it and enjoy, and get some nice diecast valve covers, and matching air cleaner. |
03-24-2020, 07:25 AM | #4 |
Quadrajet is the way to go. Best carb ever made. If you know what your doing with them. They get a bad rap because some back yard mechanic meses with them and wonders why it runs like crap. My q jet had zero bog for instance. Because it hasn't been messed with.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
03-24-2020, 12:25 PM | #5 |
National Carburetor has the carb you want for $200 remanufactured and tested. If you want a new one (I didn't think anybody made them anymore) they have that for $350 right now.
http://www.nationalcarburetors.com/l...partnum=nd4343 http://www.nationalcarburetors.com/l...num=nd4343-NEW
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
03-24-2020, 05:50 PM | #6 |
just reman your q-jet
I BELIEVE IN JOHN 3:16 |
03-24-2020, 07:43 PM | #7 |
That's a good option, if someone hasn't messed it up too badly in the last 50 years.
03-24-2020, 10:01 PM | #8 |
they haven't.................... then and now is who I use
03-24-2020, 11:09 PM | #9 |
I meant if the original poster's carb hasn't been too badly messed up by somebody in the past. I've had a few trucks that the Quadrajets were turned into junk by previous owners who tried to rebuild them.
03-25-2020, 05:45 AM | #10 |
No, Edelbrock carbs are not period correct at all. Not factory (obviously) and not aftermarket. I think Weber made their first carbs, since Edelbrock was an intake company that never made carbs.
03-25-2020, 06:38 AM | #11 |
Thanks for all the replies guys. I definitely got the information I needed and found answer I was looking for - looks like a nice Q-Jet is definitely the way to go! Unfortunately I didn't have the original one, when I bought the truck it had an old holley on it. But I'll look for a new one or maybe a good rebuilt one.
I see listings for "stage two" carbs... What does that mean? Is that for racing?
03-25-2020, 06:38 AM | #12 | |
03-27-2020, 09:21 PM | #13 |
Holley carb would be “period correct” but not factory for our trucks
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
03-28-2020, 04:21 PM | #14 |
"Trucks with Class"
FYI Edelbrock sold 99% correct, made in USA by Bosch, QJETs that were really nice carbs. They were so expensive that EB did not order more when they ran out. It is cool to use the correct QJET because everything fits correctly and works so well. Be sure your intake "matches" the QJET.
