How long should it take?
I am doing a LS swap and my motor has sat for 2.5 years. (I know) I changed the oil pump, water Pump, and every seal and gasket I could. I also replaced the oil pan so pretty much all the oil was removed from the engine. I attempted to build oil pressure today- I disconnected the coils and the fuel tank is bone dry. I tried cranking over the motor while watching a oil pressure gauge I connected. The needle never moved. I motored it multiple times, 5-10 seconds at a time. The needle never moved. They say to prime the oil pump when you have install it but I can't remember if I did that. So my question is, how long should it take to build oil pressure under these conditions?
Any suggestions what I should do? Thanks! |
Re: How long should it take?
It's probably not going to build oil pressure by hitting the starter at "5-10 seconds at a time". You really should pull the distributor and use an oil pump priming tool. You should be able to rent one for free or cheap at your local auto parts store.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
Hi Saxart, it is an LS motor, so no distributor. I don't know of a good way to prime these motors if it's already full of oil.
When I did mine many years ago I removed the plugs and let it spin. It took a little while but it did build pressure.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
#6 | |
#7 | |
![]() ![]() ![]() Let us know if you resolved the issue with the YouTube video.
When you put the new oilpump on I think you have to shim the pump,like with feeler guages three places to center the pump or no oil pressure.Someone who knows more than I do can set you straight. I do know moroso sells a pump primer for the LS engines.
'71 Cheyenne Super LWB - Second Owner in 39 Years! '70 CST/10 SWB - Soon to be Daughter's truck when finished |
All about them Ks
![]() Join Date: Jun 2014
Lots of people have issues with the pickup tube o-ring not seating correctly and or getting cut when installing it into the pump especially if the pump replacement was done with the engine in the car or truck. If you pull the galley plug and fill the pump like the video above shows it should build pressure pretty quickly. If not I’d suspect an issue with the o-ring.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's 87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue 10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
![]() Join Date: Oct 2005
Years ago I built a pressureiser out of an old fire extenquisher. I put a valve stem in the side near the top. Irun a hose from the outlet to the oil pressure outlet on the engine. I put a quart of oil in the tank & put air pressure to the valve stem watching the gauge.
Pull the trigger & pressure goes into the oil gallery. I have used this for 50 years & hundreds of engines. The oil pressure comes up as soon as the engine starts. This also works good for checking low oil pressure problems. With the oil pan off I put pressure to the system & watch for excess flow. George |
I never could get oil pressure by just cranking over either. I ended up buying a priming tool from jegs and got instant oil pressure.
It might be that since this is the 67-72 truck forum your mind went to the mechanics of 67-72 trucks, which is what this forum is for. 67-72 GM Trucks have distributors. The only "moment" going on here was posting an LS question where it doesn't belong
#13 |
![]() Join Date: Sep 2017
X2 on the oil pump, pick up tube O-ring . If you get a used LS, that O-ring MUST BE REPLACED. they get hardened over time and shrink/crack and then it's like trying to drink from a straw with a hole in it.
WTB 71-72 Original paint Medium Red hood WTB 1972 Very nice original Parchment seat belt set |
#14 |
All about them Ks
I dont feel this comment was necessary. A simple move of the post to the forum you felt necessary would have been fine. Maybe its just me...
#15 |
Nope... Not just you.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
#16 |
also notice the post also had nothing to offer help-wise other than insulting & berating the original poster. about part for the course.
#17 | |
All about them Ks
OP, did you ever get pressure?
#18 |
My favorite part was reading that an LS engine question posted in the LSx swap section was "...posting an LS question where it doesn't belong"!!!??
Good suggestions already presented and even more creative solutions online. I will add that as important as priming is it isn't nearly as critical on an engine that has already been broken in and has decent run time on rings, bearings, etc. |
#19 | |
All about them Ks
#20 |
Hi Guys,
Thanks for all the replies...except one. A little update- I did the oil pump priming procedure that hjewall2 posted. This works great BTW. Long story short.. still no oil pressure but the engine won't start either. I don't think I am going to build oil pressure until the engine actually starts short of some fancy priming rig. I pulled a spark plug and zero evidence of fuel smell on the plug. I put a noid light on the injector harness and they are being commanded to pulse so tomorrow I'm taking my injectors to be cleaned/flow checked. I believe they are gummed up from sitting so long. I will keep everyone posted! |
#21 | |
![]() you may want to check your fuel pressure at the fuel rail as well. should have 58 psi. |
#22 |
Thanks Willie, great advice! I'm guessing you check fuel pressure at the Schrader valve on the crossover tube?
#23 |
#24 |
I picked up one today Willie. Decided to go ahead and have the injectors cleaned and flow checked as well.
#25 |
![]() Join Date: Aug 2018
I made a priming tool from an old small block chevy oil pump. Just put a drill on the drive shaft of the pump, dropped the pump in a bucket of oil, and ran a hose from the pump to the plug on the driver lower front of the block it worked really well. It is the plug that takes an alan wrench to take it off.
