Old 03-28-2020, 03:38 PM   #1
barry1982
1982 GMC Sierra- cab corner wires
Hi Guys,
I am restoring a 1982 GMC Sierra. I removed the interior from the truck about three years ago to allow for rust repair. I am now putting it back together and am having a hard time with the wires that run along the drivers rocker and plug into wires going up into the cab from the drivers side cab corner. I believe one wire is for the interior light...what is the other wire for?
barry1982 is offline   Reply With Quote
Old 03-28-2020, 04:55 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: 1982 GMC Sierra- cab corner wires
Two wires would be the power and switched ground for the dome light.
Off the top of my head Orange hot and White switched ground from the door and headlamp switch but I'm not positive on those colors.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-28-2020, 06:12 PM   #3
pontiac6269
pontiac6269's Avatar
My 81 C20 has one wire that goes to the seat belt.
Eric
2001 Ford F350 EC dually 7.3
1981 Chevy C20 to K20 350
1978 Oldsmobile Cutlass Supreme 455 Pontiac
1969 Pontiac GTO 400
pontiac6269 is offline   Reply With Quote
Old 03-29-2020, 10:07 AM   #4
Pontiac1976
Pontiac1976's Avatar
As said by
hatzie: Two wires would be the power and switched ground for the dome light.
Should have connector on it cab corner Driver side if you have the rear top dome light another orange wires and white wire harness from light to the top 1/4 of the cab corner.
If you have seat belt light/buzzer as said black or white wire there (check your yr). I Have all was have mine unplugged.73-85 cars and truck I owned.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 03-29-2020, 01:54 PM   #5
barry1982
Thanks Guys....will look into it further. I know I have an orange wire....think there is also a single black wire.
