04-02-2020, 08:38 PM | #1 |
Flashing my dang computer!!
So I got my original computer to start one time and now it won't turn on the pump!! Checked everything else and power is not coming out the computer so I got another one..
Now I know there's someone one here that reflashed but I cannot remember for the life of me who that was. Can someone help me. ? 05 Chevy computer dbw
1967custom |
04-03-2020, 08:44 AM | #2 |
Re: Flashing my dang computer!!
Power does not come out of a 05 pcm if it's a ls1 style pcm. It grounds the pump relay wire. I can test it for you if needed. Pm me.
I stand corrected. Old man disease hit me again. I can test it for you if needed though.
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos Last edited by aknovaman; 04-04-2020 at 06:55 PM. |
04-03-2020, 09:56 AM | #3 |
My 04 Escalade PCM is the other way - the PCM sends a 12V signal to turn on the fuel pump.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
04-04-2020, 03:26 PM | #4 |
the PCM that went out on me is a 03 suburban with DBW and 5.3 4l602wd.
I can send it to you if you like thatd be great!! the one I have now is a 05 Silverado 5.3 DBW to replace it if I need to
1967custom |
04-04-2020, 06:51 PM | #5 |
The PCM sends power to the fuel pump relay, the opposite of fan relays. Have you plugged in the new PCM to see if the pump comes on? It should, so if it doesnt, you have a wiring problem.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
04-04-2020, 06:56 PM | #6 |
I stand corrected. Old man disease hit me again. Eric is correct. Initially misread my wring diagram. Send them to me anyways, I can read and test the PCM here.
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos |
04-13-2020, 06:47 PM | #7 |
good idea. ill do that first thing in the morning
1967custom |
04-15-2020, 01:51 AM | #8 |
chevy truck fan
if you still think you might need a "reflash" I just got done with having mine done a few months ago. I had it done by Brendan at lt1swap. he is very knowledgeable and very reasonably priced.. check him out at lt1swap.com
hope this helps... good luck |
04-18-2020, 12:38 PM | #9 |
Yup I talked to him online and he suggested I hook up the unflashed computer as well. Same issue so that told me it was the harness. Went over the whole damn thing and I found a ground I had missed hidden right by the fuel inlets in the engine!. Thanks for your help fellas!
1967custom |
