Old 04-04-2020, 03:43 PM   #1
jrusher
Turbo build in my 65
Slow days at work thought I’d post few pics of the latest project on my c10. Was recently on a holiday in mexico then had to quarantine for 2 weeks so got some quality shop time in at home .
Made my own hot side manifold used 2.5” stainless and 1.5” . Was a lot of fitting and welding but was nice to locate the turbo right where I wanted it and retain battery in stock location
I tried to stay with a 4” down pipe but couldn’t get it to fit down by frame and beside my cross over pipe so reduced it to 3”
- Used 2.250” for my cross over
- Went with a vs racing next gen 78/75 turbo
- 44 mm eBay waistegate and 50mm bov. These are supposed to be decent quality knock offs https://www.ebay.com/itm/44MM-TURBO-...72.m2749.l2649 https://www.ebay.com/itm/50MM-ALUMIN...72.m2749.l2649 https://www.ebay.com/itm/CX-Racing-3...72.m2749.l2649
- I originally bought a bigger intercooler but didn’t want to hack my rad support up totally so I got a smaller width intercooler and didn’t have to notch the rad support as much this one is 26”x12”x3” I believe
- used a stock truck manifold on drivers side with v bands
- got everything ceramic coated
Pretty much have it all finished up except bigger injectors, oil catch can and a boost/wideband gauge.
jrusher is offline   Reply With Quote
Old 04-04-2020, 03:51 PM   #2
jrusher
Re: Turbo build in my 65
Few more pics
Old 04-04-2020, 03:57 PM   #3
jrusher
Intercooler isn’t as big as I would of liked but this one fit alot better with minimal hacking to rad support
Old 04-04-2020, 10:54 PM   #4
KMC3420
KMC3420's Avatar
Excellent job. Turbo placement looks optimal. Did you mig weld your pipe together? You have a link to the wastegate and blow off valve?
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 04-04-2020, 11:12 PM   #5
jrusher
Thx. The waistegate isn’t in the best location with inlet and outlet at pretty much 90s but I had no other choice really for location. The down pipe was a pain to fit under heater box etc.
I’ll get some links for the Ebay parts
All tig welded
Old 04-04-2020, 11:36 PM   #6
KMC3420
KMC3420's Avatar
All tig welded
Thanks in advance for the links. I was going to purchase a log manifold kit but the cost is $500 plus, but I would almost prefer to buy just the log manifold and then fab up the rest of my hot side. I only have access to a mig welder though. I have seen a lot of waste gate configurations and hopefully you won’t have any issues. I bet you saved quite a bit of money doing your own fab versus the kits below.
Here is the kit KB Racing
Keagan
Old 04-05-2020, 12:17 AM   #7
jrusher
I looked at the kB , trick and fauler racing manifold $500 and up usd and then tack on another 40% for us Canadians as our dollar is crap. I also looked at the hooker manifold but I didn’t like how you still had to fab up a up pipe.
I spent about $150 for all the pipe and the flanges then some small tubing for the waistegate so say $200 for all manifold material . I’m glad I built my own as location is key for fitting everything else .
I forgot to mention I had to swap engine mounts as well as the 67-72 pedestal mounts hit the log manifold so I swapped in some square body c20 clam shell type mounts . Way better design and the set the engine up higher.
Old 04-05-2020, 08:50 AM   #8
jrusher
For the oil drain line off the turbo I was originally going to dump it into timing cover but there’s not a lot of clearance there behind balancer so the oil pan was much easier place to install fitting and it was a straight shot down pretty much from bottom of turbo . Used a 1/2 npt-10 an . Dropping the pan was way quicker as well then pulling the timing cover if you have room to pull pan of course
Aslo had to add a IAT sensor as maf is deleted and will be tuned with speed density
Old 04-05-2020, 10:50 AM   #9
Willie Makeit
Willie Makeit's Avatar
very very nice work <thumbs-up>
Willie Makeit is offline   Reply With Quote
Old 04-06-2020, 12:43 PM   #10
tinydb84
tinydb84's Avatar
Very cool!
David
Instagram: myfabguy
Old 04-06-2020, 11:49 PM   #11
Ghost's68
Ghost's68's Avatar
Very nice! Super jealous of the manifold fab work. I wish I could fab and weld lol. I just pre ordered a set of Fahler speed twin turbo setup manifolds. I’m running a single but I really like how he builds them to clear stock plug wires. Your truck will be a ripper for sure! Keep us updated.
Ghost's68 is offline   Reply With Quote
Old 04-07-2020, 01:26 AM   #12
jrusher
Thanks guys! Got a few more loose ends to finish up on it and will have it on road shortly if spring ever gets here. Still a foot of snow on the ground here
Old 04-12-2020, 10:28 PM   #13
KMC3420
KMC3420's Avatar
What boost goals are you shooting for? That turbo sounds like a high HP turbo. I am guessing you will be shooting for high boost with the smaller 44mm wastegate.
Keagan
Old 04-12-2020, 11:11 PM   #14
jrusher
I’ll probably run it at 8-10 pounds for most part. I’d like to see it hit around 650 ish hp at wheel on the dyno for a couple pulls . I was 380 at the wheel last summer
Old 04-12-2020, 11:34 PM   #15
KMC3420
KMC3420's Avatar
That seems like a good goal to shoot for. I bet you won’t have issues hitting 650. Gonna be a big jump from 380.
Keagan
Old 04-24-2020, 12:37 PM   #16
jrusher
Rerouted my exhaust abit and made a cross over to retain my dual exhaust out the back . Was a pain making the cross over to clear suspension and driveshaft etc.
Old 04-24-2020, 12:41 PM   #17
tinydb84
tinydb84's Avatar
Nice work on that exhaust. I wish I had a lift.
David
Instagram: myfabguy
Old 04-24-2020, 10:33 PM   #18
jrusher
Thx! Luv my 2 post lift so easy to get at everything. I wouldnt be doing half the work i do on these old vehicles without a lift. Getting too old to lay on the ground etc
Old 05-21-2020, 09:06 AM   #19
jrusher
Finally got my truck tuned yesterday and she layed down some good numbers. 650hp @ 9 psi and 580 ft/lbs torque. I did have to change out that smaller intercooler for a larger one. I’m really happy with the results had a perma grin ripping around in it last night. I’m going need rear tires very soon lol
Old 05-21-2020, 09:23 AM   #20
jrusher
Old 05-21-2020, 09:56 AM   #21
KMC3420
KMC3420's Avatar
Awesome numbers, congrats. Did you have any issues with Boost creep with your Wastegate being at 90 degrees?
Keagan
Old 05-21-2020, 10:06 AM   #22
jrusher
THanks! No creep issues gate seems to be working well
Old 05-21-2020, 10:11 AM   #23
KMC3420
KMC3420's Avatar
My plans are to run the 7875 turbo as well but the .96 version. How quickly do you begin building boost, what RPM?
Keagan
Old 05-21-2020, 10:29 AM   #24
jrusher
I haven't had a chance to check rpm. Was too busy trying to keep thing straight on road lol.. It does spool quick
Old 05-21-2020, 10:34 AM   #25
KMC3420
KMC3420's Avatar
haha, I am sure that is true. Thanks for sharing and let us know how it does once you have more seat time.
Keagan
