Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Closed Thread
Old 04-06-2020, 06:24 PM   #1
bcfishon
1972 suburban parts and cuts
I've never posted to sell parts and did not plan to but this suburban fell into my possession and I have no use for it but could not pass it up. I will cut up what someone wants and have some various pieces but not too much. Have never shipped before but willing to learn a new trick so if you see something you need holler and I will shoot numbers and will ship with your assistance. po cut off roof and wacked the pillars.and firewall.
bcfishon is offline
Old 04-06-2020, 06:33 PM   #2
randy500
Re: 1972 suburban parts and cuts
Price on the rh B pillar? Picked up
randy500 is offline
Old 04-06-2020, 07:13 PM   #3
bcfishon
How about $40
bcfishon is offline
Old 04-06-2020, 07:13 PM   #4
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Is there a window left in the fake door? Is it a green tinted one?
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline
Old 04-06-2020, 07:14 PM   #5
randy500
Originally Posted by bcfishon View Post
How about $40
I will take it.
Traveling down your way next week probably.
randy500 is offline
Old 04-06-2020, 07:16 PM   #6
71blksuper4x4
SWB 4x4 Collector
How rusty is the cab mounts that connect to the b pillars?
TREVOR
Old 04-06-2020, 07:22 PM   #7
randy500
I need the “B” pillar cut at the roof rail and down through the front and rear rockers, if you can save the floor support for Trevor thats fine. I think it connects behind the pillar.
randy500 is offline
Old 04-06-2020, 08:24 PM   #8
bcfishon
I will take it.
Pm sent
bcfishon is offline
Old 04-06-2020, 08:26 PM   #9
bcfishon
Yes
bcfishon is offline
Old 04-06-2020, 08:27 PM   #10
Disastro
What's the condition of the rear sill? (Panel that the tailgate bolts to.)
Disastro is offline
Old 04-06-2020, 08:34 PM   #11
ShortbedClayton
Can I get some close ups of the circled areas? Need the upper edges to finish off my crew cab 4 th door side. Need at least 24”
ShortbedClayton is offline
Old 04-06-2020, 08:34 PM   #12
bcfishon
I'll look closer for you
bcfishon is offline
Old 04-06-2020, 08:40 PM   #13
ShortbedClayton
Also interested in the false door window regulaor
Old 04-06-2020, 08:45 PM   #14
bcfishon
I snapped these.real.quick
bcfishon is offline
Old 04-06-2020, 08:47 PM   #15
randy500
I need the entire B pillar as marked.
randy500 is offline
Old 04-06-2020, 08:48 PM   #16
bcfishon
I will look at it,could not get that window to roll either way but it may just need a little spray and motion,it's on my list sir
bcfishon is offline
Old 04-06-2020, 08:50 PM   #17
ShortbedClayton
I need infront of that false side basically where the door seal glued to put to the drip edge. Cut flush off with the solid fake side.. and as much of what’s left after removing the b pillar for randy.. price?
Old 04-06-2020, 08:52 PM   #18
ShortbedClayton
Sorry to be confusing but it’s hard to explain.. no rush on my part. Thank you..
Old 04-06-2020, 08:54 PM   #19
bcfishon
Randy,
Here are some pictures of that piece ,take a gander and if you want it it's yours
bcfishon is offline
Old 04-06-2020, 09:01 PM   #20
randy500
Randy,
Its useable for my purpose, cut the rear rocker panel like the front one and then the floor. Which is through that floor support, unless you want to dissect the bottom So Trevor can get the floor support (best idea)
Just cut the top at each side of the top rail so clayton can get his top rail piece.
randy500 is offline
Old 04-06-2020, 09:02 PM   #21
randy500
The 6. Bolts loosen up things on the floor support but its also spot welded, prob can separate it with an air chisel.
randy500 is offline
Old 04-06-2020, 09:18 PM   #22
bcfishon
It has some scale but hasn't gone through anywhere,it has a dent on the edge but bad, would use it if I needed one.
bcfishon is offline
Old 04-06-2020, 09:24 PM   #23
bcfishon
I actually understood that and it's in my skill range,your name is on it
bcfishon is offline
Old 04-06-2020, 09:28 PM   #24
bcfishon
Here are some more,let me know if you need some more sir.
bcfishon is offline
Old 04-06-2020, 09:32 PM   #25
bcfishon
And more
bcfishon is offline
Closed Thread
