04-09-2020, 10:09 AM | #1 |
*Replacement Turn Signal Lever*
I have a 1984 Chevy steering column in my 49 truck and I'm wanting to replace the turn signal lever with one that does not have the wiper, cruise control, etc. on the lever. Do they make a replacement that is just a rod like the tilt lever is in the pic. The ones I've seen online have a different end where it connects inside the column. I found a billet set of 3 as in the pic but the end looks different. Anyone have any knowledge on how it connects inside the column or what would work. I should have paid closer attention when I replaced the turn signal switch.
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck Last edited by Zippi; 04-09-2020 at 10:15 AM. |
04-09-2020, 09:21 PM | #2 |
Re: *Replacement Turn Signal Lever*
In 84, the wiper controls were integral with the turn signal lever, with cruise control being an option.. The best you can do is find a lever that eliminates the CC switch. The wiper control is there for the duration. I don't remember the exact year (probably 1984) when GM moved the headlight dimmer switch and the wiper controls to the column and integrated them with the cruise controls.. Sure makes for a busy turn signal lever..
04-10-2020, 07:05 AM | #3 | |
Thanks for the info. Did some research and 84 was the year it all went to the column. My column has the dimmer switch at the bottom of the column which is controlled by a rod and all the goodies on the signal lever. I have a couple emails out to vendors that sell aftermarket billet turn signal lever kits that come with the tilt & signal lever and the hazard button. Hoping they have a kit for my column.
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck |
04-10-2020, 09:10 AM | #4 |
I have not seen one for the GM 84 up style column. But for the 83 down column.
they do have a few out there. There is re-placement signal lever like factory. you could get. (LMC, Classic Parts, & a few more) I think Eastwood sells really nice looks like all the real thing, chrome paint that you could paint the black plastic make it match the theme. good look on your search
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
04-10-2020, 03:40 PM | #5 | |
04-10-2020, 10:24 PM | #6 |
Old member
The only thing I know you could do is take your switch out and buy a stock metal, not billet and weld the end of yours to the switch you buy to work and not have the wiper's and such on it.
04-11-2020, 07:21 AM | #7 | |
Not a bad idea. I'll keep that in mind. Don't have a welder but I guess I could find someone.
04-11-2020, 12:42 PM | #8 |
It is fairly easy to replace the column dimmer switch with a floor mount version. As mentioned above, the 84 dimmer is at the base of the column. The connector kept the same pattern as the floor dimmer but as the wires are too short, you will have to splice and extend. I did this on a CUCV as the column dimmer switch was shot and I wanted the dimmer location/function to match my 75.
This doesn't solve the lever question but does move one function out of the mix. |
04-14-2020, 09:09 AM | #9 |
look closely, this is my 89...replaced very easily. i added a hidden switch to control the wipers.
04-17-2020, 09:23 AM | #10 |
Looks like a billet lever. Is it the pop in kind or bolt on? If it's a pop in kind do you have a link to where you got it? Thanks.
04-20-2020, 11:45 PM | #11 |
Old member
You could pull your lever out and buy the billet set and take it and cut the end off of it and make it work I bet with a dremel tool and some time grinding it.
04-23-2020, 12:59 PM | #12 |
i dont recall where i got them, and i have since sold the truck.
i dont recall it taking much effort to install |
04-24-2020, 08:01 AM | #13 | ||
I see you have these options on you signal lever - cruise control, wipers. As said you could try weld the tip on your new alloy stock but it will stick out about 1-1/4" more then it would. This will make you lose the option of cruise control. (1)option: If you do not care about the cruise control you could get a all black factory OEM signal lever 84-87 with (Mist OFF L0 Hl) markings this will fit you can pain with some of the alum paints or some of the chrome like paints or combo of the candy chrome paints. and it will fit in more like you want.(this will look like your now but will not have the button on the end or the switch horn sticking up for the resume of the cruise control.) (2) option: You can change your column to 73-83 style with tilt or with out tilt. This means you have to change your dash face bezel to 73-83 to the stye your looking for to get the dash mount wiper switch. then you have re-wire the wire switch to the dash switch. https://bowtieguy.proboards.com/thre...ce-bezels-fits this will help show you the break downs. This is pic shows wiper motor break down. https://bowtieguy.proboards.com/thre...-washer-repair I hope this May help you.
04-24-2020, 09:15 AM | #14 | |
04-24-2020, 06:48 PM | #15 | |
With all due respect, you're going to an awful lot of trouble just to get rid of a lever.. |
04-24-2020, 07:32 PM | #16 | |
