11-08-2020, 12:23 AM | #1 |
Clutch safety switch-
I converted my 85 from auto to manual. The new clutch safety switch has two female plugs. One is for the starter interrupt,. not sure what the other is for but it doesn't matter. Anyway, there's no way to use female connectors on it, the male spades are embedded in the plastic plug.
Anybody have a lead on this or able to snip me off the plug from a manual trans equipped square body? Here's some photos. It's the one nearest the firewall or on the left in the pic. Last edited by SunSoaked; 11-08-2020 at 07:54 PM. |
11-14-2020, 11:15 AM | #2 |
Msgt USAF Ret
Re: Clutch safety switch-
Have you had any luck with this yet?
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-14-2020, 11:33 AM | #3 |
Yes. A member on another site has a 89 v30 he's parting out. Someone bought the pedal assembly and I was able to get the factory plug with pigtail.
Thanks VetteVer. If you know of a source of oem plugs that would be nice for future reference. |
11-14-2020, 12:38 PM | #4 |
Msgt USAF Ret
Since you had the automatic trans wiring harness you wouldn't have had the harness plug so I know your dilemma and I was going to suggest mounting a brake light switch and hard wiring the harness neutral switch wiring into it. Good that you found what you needed though.
Here is a good source for any parts for our trucks. https://www.partsgeek.com/ymm/1985/c...op&scat=clutch. Second row, far right. It;s your switch but no connector.
11-14-2020, 02:00 PM | #5 |
Moderator
Contact these guys maybe you'll get lucky - https://www.repairconnector.com/
11-14-2020, 02:51 PM | #6 |
Msgt USAF Ret
This maybe it.
https://www.rockauto.com/en/catalog/...ector,neutral+ scroll down to neutral safety switch.
