04-22-2020, 09:15 AM | #1 |
Saddle tanks ? Impala gas tank solutions?
Hi gang,
I have 69 C20 Camper Special and it has the 2 poly saddle tanks. They have very old punky fuel and at least 1 of them is leaking. Do they still make them anywhere, or has anyone found an aftermarket tank that could be placed in the same location? My goal is to get rid of the in-cab tank, and I don't want to put a filler neck thru the steel bed. I don't want to remove the 8 foot bed and cut into the frame for side filler The only solution coming to mind is using the location where the saddle tanks are, or I am starting to research more about a late 1960s Impala tank, and get a hinge license plate bracket and hide the filler behind that. Also, are the poly saddle tanks baffled? Are the old impala tanks baffled? We are doing an LS conversion next week. All suggestions and comments welcome, I'm quickly learning a lot. Thanks |
04-22-2020, 02:29 PM | #2 |
The Older Generation
Re: Saddle tanks ? Impala gas tank solutions?
Evidently no one has used the poly tanks. Some members have used the rear steel or aluminum tanks and put the filler neck behind the rear marker light or the tail light If you type "marker light fuel filler" or "tail light fuel filler" into the Google box up above, click on the circle in front of "67-72chevytrucks.com" and click on the google button. you will see many pictures and instructions on how to do them..... LockDoc
04-22-2020, 02:40 PM | #3 |
Thanks Leon, I have been trying to research the forum. I didn't try that wording in the search. I have been oping to find the easiest solution. Most I seen so far have been tanks swapped with the bed removed.
I'll try those searches shortly. |
04-22-2020, 02:40 PM | #4 |
Camaro tanks are popular too for the rear with filler behind the plate.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
04-22-2020, 02:45 PM | #5 |
Thanks Demian5,
Any idea of what years work best? |
04-22-2020, 09:34 PM | #6 | |
04-22-2020, 09:43 PM | #7 | |
The one on the board, right below the Google search box. See picture below. LockDoc
04-22-2020, 09:45 PM | #8 |
Found it! Thank You for Your patience!! Also sorry to the OP for hijacking His thread!
Carl |
Tags |
gas tank; relocation, impala gas tank, ls conversion, saddle tanks |
