Old 04-25-2020, 12:28 PM   #1
ibinyth
12 bolt power limit questions
I have a 12 bolt in my 70 c10, just rebuilt it with trutrac 3.73, moser 30spline axles, and a bearing preload screw cover. My question is what sort of power can I expect this thing to handle and does an automatic make a difference vs a manual?
ibinyth is offline   Reply With Quote
Old 04-26-2020, 12:26 AM   #2
vince1
Re: 12 bolt power limit questions
I know on new trucks autos have higher rated pulling capacities than manuals. Smoother power to the wheels?
Maybe your differential will be OK with spinning the wheels a bit. Maybe not so good trying that if you have a lot of weight on it. Are you planning on pulling with it?
vince1 is offline   Reply With Quote
Old 04-26-2020, 01:21 AM   #3
Ziegelsteinfaust
The weakness in the truck 12 bolt was the pinion diameter. Or its biggest difference from the car version.
If your running street tires under 30" diameter your good for 500-600 hp. Alot of that depends on how sticky the tires your using, and how hard you launch. So there is no exact science on this.
The bearing support cover is among the best things you could of done. When the caps walk it tears up the weaker pinion which is what typically dies under repeated abuse. Personally I have never had a axle break on me, but I tore up several gear sets. A few were likely from cap walk. Opening up pinion/gear seating, and well the rest is history.
Other things that change durabilty big time. Are heavier, and taller tires. Heavy or overloaded vehicles. Running a C10 when you should of gotten a C30.
As of late I have become a fan of the brand F 8.8 rear end. It has large spline counts, and with weld on 9" ends. To me it is the best light duty rear end to build due to economic concerns You can use a bearing support cap, and studs. Only down side is like GM rears no easy gear changes in a couple hours like the 9 inch. Sure you can swap the whole axle, but it is a bit more involved.
Ziegelsteinfaust is offline   Reply With Quote
Old 04-26-2020, 08:25 AM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
The GM Truck 12-bolt is a VERY stout rear end. I've been pounding one with a 396 and a 427 for years and it's held up nicely. I welded the tubes, replaced the trailing arm perches with CaptainFab's perches, and added the Moser cover. They are VERY reliable. The day I break mine is the day a full floater Dana 60 or Corporate 14-bolt will go under the truck, just rubs me wrong to stick a Dorf anything under my Chevy...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 04-26-2020, 12:31 PM   #5
sweetk30
sweetk30's Avatar
you can upgrade the main cap bolts for a stud kit for a ford 8" if i recall . this holds them better than the stock bolts do . ebay for 25-30 bucks a set new .
yep found it in my build pics i saved . arp kit 250-3008 part # . and i did aftermarket HD 4x4 style spring pads for longer length to help control axle wrap . and less prone to crushing . also found the stock perches were off from each other over 3/4* in there clocking . i also did the detroit true trac and TA cover on mine .
have yet to run my setup as the truck is not done yet . but hope to at some point . . . .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 04-26-2020, 03:52 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
This ^^^
These are great rear ends that will take a lot of abuse. People really tend to sell them short for some reason. I have yet to break one, and I am not easy on mine at all! I added the Moser diff cover as well.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-26-2020, 05:16 PM   #7
ibinyth
I appreciate all the input fellas, I'm not too terribly worried about it. Just curious how much abuse it'll be able to take, it's mostly a street truck. That being said I know how I drive and the next motor will be making a minimum of 500 wheel and up to 650, I'm going to attempt to keep it at the 500 mark but no promises. The truck doesn't haul anything, bedsides are tube mounted and no bed floor, unfortunately my suspension setup in the rear mimics pchrods c10r so the axle perches are there to stay. I'll see if I can figure out a way around it to prevent axle wrap. Tires are a 315/30r18 on a 18x11, truck isn't together yet just now getting the time to start putting it back back together. It's a ways away from the road, but info like this helps in making sure it lasts a while.
Old 04-26-2020, 06:42 PM   #8
sweetk30
sweetk30's Avatar
https://www.calvertracing.com/caltracs.html
heard good stuff about these guys . if i have problems its my 1st choice to go to .
Old 04-27-2020, 01:52 AM   #9
burnin oil
Transmission towing capacity is mostly due to maxing out the transmissions design strength. Dodge was the last manual 1 ton and they limited torque to around 600 foot pounds. Demand was low for a high strength manual so autos got redesigned to take the 1000 foot pounds that the motors are making now. They also use torque management tuning to lessen the bang at shifts on an auto but the manufacturers had no control off the average idiot dumping the clutch. A heavier duty manual could be made but shift quality would be less so it was cheaper and easier for the big 3 to dump them.
As for the 12 bolt strength. I broke one basically. I tore every bearing out of it but the gears held. You know that you are hooking it when you drive the axleshaft through a brand new Timken axle bearing repeatedly. I got to the point of changing them on the side of the road when I was in high school. For all the abuse that truck took I don't think you will have an issue until you start to run cheater slicks.
burnin oil is offline   Reply With Quote
Old 04-28-2020, 02:52 PM   #10
Ironangel
Ironangel's Avatar
Matching the gear set to the motor and transmission is key to longevity of all three...The more HP that motor spins up, the lower the gear you can run. In other words, you don't necessarily have to tear the guts out rear ends and transmissions with 3:08 gears when a 3:73 or 4:11 would have lived transferring HP to the tires. I'm running a 4:56 with a built Turbo 350, and yes I have a 400 THM for when the 350 lets go. This new motor will undoubtedly find the weaknesses...But the transmission and rear end have lived through two motors pursuing my 12 second dream...
"Two Seventy Two's"
02 3/4 ton Express
Old 04-28-2020, 04:25 PM   #11
vince1
When I got my truck I had to tow it home across the road backwards with the pinion flopping around. Towing forward the wheels would slide. I guess they ran it out of oil so the 250 had no trouble trashing it. It was a 3.73.
The replacement 3.07 was full of some substance that felt like sand. I'm getting more life out of it by having cleaned it out and changing carrier bearings and axle bearings set to run in a different spot. I'll have to see how it lasts with 2 more ponies in front of it.
I did see a Ford diff (not a 9") break more than fifty years ago when some kids were giving it all they could while driving it around town. The carrier cap bolts broke on that one so maybe studs would have been better.
Old 04-28-2020, 07:32 PM   #12
Tom
driving is in my blood
Tom's Avatar
Anything can break. I blew up a Sm465 transmission that everyone thinks is bulletproof. That being said, the stock 12 bolt in the truck survived and is still going even though the trans died.
Old 04-28-2020, 10:28 PM   #13
burnin oil
That takes skill! The only one I have ever seen broken internally had the syncros moded by cutting off every other tooth for speed shifting. Not mine. On my 465 I did have to install new sintered bushings. That was In the same truck as the 12 bolt that I tore up. Considering I torqued it enough to bend the floor pan on more than one occasion I am surprised that I never broke the mount bolts. Always driveshafts, axle bearings, or ujoints.
12 bolt, axles, posi
