Old 04-26-2020, 11:26 PM   #1
CarlsLQ9SS
CarlsLQ9SS's Avatar
60lb oil pressure gauge and LS Swap
Im doing a ls swap on my truck and I am concerned about the factory 60lb oil pressure gauge. How well does it hold up or do I need to just change it to the 80lb gauge? Thanks in advance, Carl
CarlsLQ9SS is offline   Reply With Quote
Old 04-26-2020, 11:33 PM   #2
randy500
Re: 60lb oil pressure gauge and LS Swap
Its not going to leak or break its a very sturdy gauge. I had a 60 on my cummins for a lomg time, unless hot in the summer it was always pegged. No issues
randy500 is offline   Reply With Quote
Old 04-26-2020, 11:33 PM   #3
randy500
I did see a clean 80 psi guage on the parts forum today....
Old 04-26-2020, 11:34 PM   #4
CarlsLQ9SS
CarlsLQ9SS's Avatar
Ok, thanks. I knew it would peg out but wasnt sure how it would hold up.
Old 04-26-2020, 11:43 PM   #5
CarlsLQ9SS
CarlsLQ9SS's Avatar
Yea, I seen it too. I should have just took the whole set up when I had the chance. lol
Old 04-27-2020, 12:57 AM   #6
randy500
I bought it hoping the air pressure gauge was nicer than the one i have. They are about the same, nice but not outstanding.
Old 04-27-2020, 02:13 AM   #7
CarlsLQ9SS
CarlsLQ9SS's Avatar
I know it was used on dump trucks, but what other trucks did the air pressure gauge come in?
Old 04-27-2020, 08:08 AM   #8
nsb29
nsb29's Avatar
Why would you think an LS would have more psi than any other motor?? I have a stock gage with normal psi
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 04-27-2020, 09:22 AM   #9
CarlsLQ9SS
CarlsLQ9SS's Avatar
I know they idle at about 40lbs when hot, and around 50 or maybe a little more cold. but when you are wide open throttle i have seen 70 to 80lbs and with a 60lb gauge i didnt know if it would hold up.
Old 04-27-2020, 10:17 AM   #10
nsb29
nsb29's Avatar
Isn’t the oil relief valve set 60 PSI
Old 04-27-2020, 12:52 PM   #11
CarlsLQ9SS
CarlsLQ9SS's Avatar
I also have a high volume pump. Not sure about the relief valve.
