Old 04-28-2020, 06:51 PM   #1
sammywells
header clearance issue
working on my 68 c10, just put some flow tech headers on my 350 and the headers hitting the lower A-arm nut towards the rear on the drivers side. The engine mounts are from western chassis, tubular mounts mounted in the forward position. Looks like i could move the mounts to the rear set of holes and it would no longer hit. The cab is not on right now and was wondering if anyone has used these mounts with headers and had this problem and if i move the mounts to the rearward position will the hei hit the firewall
sammywells is offline   Reply With Quote
Old 04-29-2020, 09:50 AM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: header clearance issue
Use a ball peen hammer and you can "customize" the header tube to fit.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
