04-30-2020, 08:38 PM | #1 |
LQ4 Teardown & Rebuild
I have started the teardown on my LQ4 engine. I plan to rebuild it with a cam and 706 heads for a good power bump while maintaining reliability.
This will be going into my 71 4X4 GMC and will be backed by an NV4500/NP205. One day I will post about the full resto! The video shows the teardown process. For those who haven't disassembled one of these engines yet, I hope this helps you! They are actually quite easy. https://www.youtube.com/watch?v=XmO3frkwG_0&t=4s |
05-01-2020, 01:59 PM | #2 |
Re: LQ4 Teardown & Rebuild
Sweet build. Look forward to watching it come together. Love my Lq4 so far...
05-01-2020, 09:44 PM | #3 |
I am just finishing up my lq4, Have 862 heads with a BTR stage 3 V2 cam and a Blackbear tune. Sounds like our builds will be similar except my truck is 2wd
05-05-2020, 10:29 PM | #4 |
I went back and forth on heads and cam selection. I ended up doing a sloppy stage 2 cam, reworked 318 heads, pac springs, gapped rings, ls6 lifters and everything that goes with a typical rebuild. First ten second start up the other day seems promising.
05-06-2020, 12:13 PM | #5 |
Looking good. I torn my LQ4 down, had it cleaned, honed and new bearings put it. I sent my heads to Texas Speed for their CNC service and also had them decked .030 to bump compression to around 10:1. I went with their baby 224r cam. It made a little over 400 at the tire not leaning on it too hard. Your build is very similar. You will like it!
