05-04-2020, 08:36 PM | #1 |
Brake Parts Needs
I would be in need of a source for some specific brake parts.
My truck is a 1970 Chevrolet C-20 3/4 ton 2WD with a Dana 60 rear and leaf spring suspension. Apparently the Rear Drum Brakes are a 12 x 2 1/2 dimension. I would be in need of the self adjuster arm. Mine is of a 2 piece design and no local chain stores have them, I can get everything else. In the picture you will see what Napa sold me as a "Give it a try" part. Its the Gold Zinc plated part above the actual self adjuster. If anyone knows of a New Supplier source I would greatly appreciate it! |
05-11-2020, 12:39 AM | #2 |
Re: Brake Parts Needs
Looks like they sold you one for smaller diameter brakes, perhaps 1/2 ton brakes.. There is a privately owned automotive parts store locally where I get probably 90% of my C/10 parts. They have connections to most major parts manufacturers.. Give them a try.. Ask for Matt or Tony, tell them I sent you.
https://www.yellowpages.com/elkhart-...supply-8754718 |
