05-24-2020, 05:20 PM | #1 |
When to use a relay
Outside of the obvious (30A draw etc) ........ when should you use a relay ?
I am planning on putting both of the devices on my truck. I have spared fused circuits from my EZ harness. Debating on plugging straight into them or adding relays. Both products below recommended relays. ~7.5A fused https://www.amazon.com/Audio-Systems.../dp/B00IBI50NK https://preview.tinyurl.com/y7v839y5 ~ 3A tested with multimeter So this got me thinking - I know the basics of relays and how to wire them ...... but why use them for those mid level draw accessories ..... 5A-10A. Cant these be protected adequated with correct gauge wire and fuse ? I mean there are plenty of 5-15A circuits on these wiring harnesses ? I know would need to measure length of wire an guage to ensure could carry load ...... but outside of that ?
FAKKY 57 PANEL BUILD |
05-24-2020, 06:15 PM | #2 |
Re: When to use a relay
I think some people end up using relays because the decorative switch they want to use for the device will not handle the current, although the wires going to the switch and device may be able to.
05-24-2020, 07:28 PM | #3 |
I set mine up for big amp draws, and ign. hot stuff. So I know it's turning off when key is off.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
05-25-2020, 09:47 AM | #4 |
I guess what I dont get is why for example would a 7.5A max draw radio recommend a relay ....
when for example a cigarette lighter which draw 10-15 amps .... sits on just a fused circuit..... no relay. The decorative switch thing makes a little sense ...... but most switches should handle 10A. http://www.bosch-classic.com/en/inte...300300x_1.html https://www.elecdirect.com/cole-hers...xoCiK8QAvD_BwE etc
05-25-2020, 11:27 AM | #5 |
That stereo looks interesting to me. I think you have a good idea putting that in your truck. Have you hooked it up enough to hear if the speakers sound good and have decided where to mount them? Let's see a picture of where in the instructions it is suggesting a relay, perhaps how they word it will give a clue about the reason they suggest one.
05-25-2020, 11:29 AM | #6 |
It could be a general recommendation to avoid overloading the standard wiring harness. Older vehicles often don't have a lot of extra power capacity designed into the harness. By using a relay that pulls power direct off the battery or a high power junction, you lessen the chances of exceeding the max rating of the OEM harness.
05-25-2020, 11:46 AM | #7 | ||
Which led me here.
05-25-2020, 12:38 PM | #8 |
It's interesting the diagram shows a relay but the written instructions just say hook it up to a switched source. I think the instructions are poorly written or poorly cobbled together. Here is my theory: Somebody at some point may have drawn that diagram for a customer who was asking them how to incorporate a time delay relay so the radio continues to work for 30 minutes after shutting off the motorcycle. You can buy time delay relays like that, even adjustable ones. So the diagram probably was accidentally included in the instructions, without explanation.
05-25-2020, 12:43 PM | #9 |
Interesting ^^^
Well curiosity got the better of me so I amped it out ...... and its generally 0.5 to 1A at full volume. There is a spike on "boot" for around 0.1 second to 3A. Think Im fine The sound - is awesome for what it is ....... 2 small speaks tied to an amplifier. $70. Like my dad says - good enough for the girls we run with. Ill post a video later. Only downsides I can see are ..... 1) Large connection "beep" on startup - annoying - wonder if that can be fixed or not. 2) No controls - only volume. Everything done through phone or AUX input. But thats fine as generally these days all I do is run stuff through my phone anyway - reason for buying. 3) In high bass scenarios --- it starts to lose it a little ... not bad enough that your like yuck ... bt that you might back it off 20%. Good value and importantly goes with truck and my style of playing music.
05-25-2020, 01:49 PM | #10 |
I would be interested in seeing/hearing a video. The start up beep sounds like it would be annoying. Is that when the bluetooth device connects, or when the unit gets power? If it is when it gets power I suppose you could add a 5 second on power on delay relay and use it to connect the speakers after the beep occurs. The things you have to do when you get a Boss instead of a Bose... :-)
05-25-2020, 06:48 PM | #11 |
FAKKY 57 PANEL BUILD Last edited by FAKKY; 05-25-2020 at 07:03 PM. |
05-25-2020, 07:06 PM | #12 |
Turn your PC sound up
Definately loud enough ..... wife asked me to turn it down standing at door .....
05-25-2020, 09:24 PM | #13 |
Yes, sounds pretty good from here.
