Old 05-25-2020, 05:19 PM   #1
lks dcvn
lks dcvn's Avatar
Easiest way to wire up factory tach?
I'd rather not spend ~$25 to buy a tach harness if I can help it.
Checking to see if this is the correct/easiest way to wire up a tach in my 70 GMC Jimmy. Single wire run to the HEI tach post through the firewall and the other 2 (12V and ground) wires stay local like in the pics below that I found on the forum from older posts.
Thanks.
lks dcvn is offline   Reply With Quote
Old 05-25-2020, 05:46 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: Easiest way to wire up factory tach?
Just run the hot wire to fuse block to unfused 12 volts. You can do it that way but it may not be as good of connection.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-26-2020, 02:49 PM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
The tach wiring should be at least 14 gauge but 12 is preferred.
Do not tap tach wiring to the cluster hot feed. It is only 18 gauge and the tach needs 12 gauge wire.
The tach will ground to the cluster tin so really no external ground is needed but never hurts. Run the battery voltage directly to fuse panel "ign feed" with 12 gauge wire. Also 12 gauge to the neg side of coil.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 05-26-2020, 05:33 PM   #4
lks dcvn
lks dcvn's Avatar
Cluster Feed or Ign Unfused for the tach power?
Thanks for the update. I can easily update the wire gauge and connections now that I have everything apart.
