05-27-2020, 05:57 AM | #1 |
is this how it's done ????
If you raise your 4x4 4 inches does it mean you have to lengthen the drive shaft or it leaks tranny fluid ????
05-27-2020, 07:28 AM | #2 |
Re: is this how it's done ????
short answer is no, 4" of lift does not automatically or categorically necessitate driveshaft lengthening..
can a 4" lift in some circumstances require driveshaft lengthening? sometimes but not always.. can lifting a 4wd vehicle create transfer case leaks? yes, but not necessarily by virtue of lift alone.. slip yokes are designed to operate within a range of suspension travel, some accomplish this better than others.. worn yokes and seals simply running in different positions can create leaks where otherwise parts in better condition would not leak.. short wheelbase vehicles may experience driveline angle issues more so than overall length issues.. suspension travel is also an important factor that dictates required driveshaft lengths, yoke engagement, u-joint type, etc.. apologies for the vague answer but there is a myriad of criteria to consider for a proper answer to your question.. knowing exactly what you're working on, exact lift from stock height, method of lift, etc. will yield more accurate responses.. please share some details about your project and good luck!
I started out with nothing - and I still have most of it |
05-27-2020, 03:16 PM | #3 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-28-2020, 04:48 AM | #4 |
1987 k10 short box , lifted 4 inch and it has a small of tranny fluid leak coming from around the u- joint at the yoke , it's not the seal .
This lift was already done to it when I purchased the truck |
05-28-2020, 06:27 AM | #5 |
I'm not familiar with 87 k10 transfer cases specifically but sounds like weep hole in the yoke.. this allows linear movement of the yoke over output spline during suspension travel without creating hydraulic lock internally.. again, I'm not familiar with your specific transfer case as to what kind of spline sleeve internal seal or o-ring it may have if any.. but you can at least verify whether the yoke has a weep hole and if that's the source of the leak.. it may also make a difference which shaft it is, front or rear, as they may have different seal arrangements..
google "slip yoke weep hole leak transfer case" to see a plethera of articles that may match you symptoms.. hopefully someone more knowledgeable about your specific series of truck will clear this up for you.. and for future reference, a little more descriptive thread title may draw faster pointed answers to your questions good luck!
