05-29-2020, 09:49 PM | #1 |
Carpe manana
WTB: OEM ground straps
Anyone have OEM ground straps for sale or trade? Thanks, Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
05-30-2020, 08:28 AM | #2 |
Equal opportunity joke ofender
Re: WTB: OEM ground straps
Pete
How long is it? I think I have some hanging on the wall, just don't remember what model they came off of
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
05-30-2020, 09:06 AM | #3 |
Active Member
I have a big jar of these I have saved somewhere. I will check. I need to save one set for my good truck. Repops are OK on the rest. Do you just need the tw short ones?
05-30-2020, 09:26 AM | #4 |
Carpe manana
Thanks guys. I could use at least one more aiming for two each of the shorter one that’s about 6.5” long and the longer one that’s about 12” long. Mine are frayed pretty good.
Here’s a pic of the longer one.
05-30-2020, 11:50 PM | #5 |
Pete I’ve got these they are 10 1/2 inches
05-31-2020, 07:20 AM | #6 |
Pete,
This is all I could find at the moment. Short one is around 10" and the longer ones are 12-13" .
05-31-2020, 09:06 AM | #7 |
Carpe manana
Gunner thanks I’d give those a try for the engine grounds if they have one connector that’s open not an intact hole to slip onto the valve cover screw. Richard I’m thinking the shorter one would be useful for cab to frame ground on my k20 and a long one could be used to ground the bed. I used thin asphalt pads between the frame and the bed and would like to add a ground there. My hazard lights stop blinking when I press the brake pedal - thinking ground might fix this as the wiring is all new.
Let me know what you guys need for the straps. Thank you.
05-31-2020, 09:28 AM | #8 |
One short strap on the way Monday. Been cleaning garage !
05-31-2020, 09:29 AM | #9 |
Active Member
Deadhead, I found a couple good short ones. I see there are two lengths of long ones, 10 1/2 and 12"?? I am wondering if there are longer ones for BB or 4x4 ?? Will send PM. Chuck
05-31-2020, 09:47 AM | #10 |
Carpe manana
Thanks Mike!
Chuck that’s a great question. The oem engine grounds for my 4wd are easily 12” and can be stretched out further than that. 4wd engines sit closer to the firewall so I’d think these would be shorter. There’s got to be some reason to account for the differences. Here’s an excerpt I found here from the factory assembly manual - looks like a sb v8. I’ll try to find the page and see if there are more details therein.
05-31-2020, 09:56 AM | #11 |
Just to let you know Pete. Hazards do stop blinking when you hit brake pedal. They are utilizing the same filament in the.bulb. Brake light portion. Turn signals and brake lights are same function on the bulb as well as 4 ways. Running lights are the other filament. I think on all vehicles they stop blinking when you depress brake. Nothing wrong with wiring. But cant have to many grounds.
05-31-2020, 10:10 AM | #12 |
Carpe manana
Lol! Lois thanks for letting me know. I swapped out the intermediate harness and tail lamp housings. Have to admit I’ve never tried the brake with the hazards on before making this change so figured it was a ground.
06-01-2020, 05:33 PM | #13 |
Did you get fixed up on ground straps?
My C10 has a 10" on the passenger side and a thick one, like in post #4 on the drivers side. My K10 has 10" straps on both sides as does my Longhorn. Pictures of the K10.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
06-02-2020, 07:40 AM | #14 |
Carpe manana
Larry thanks I believe I’m all set. I appreciate the photos and these point to variation in ground strap use by GM.
