05-31-2020, 12:11 PM | #1 |
Low Budget Alternative Tow Hooks
Would take a little engineering to mount but you sure won't hurt these bad boys by using them for their intended purpose. Each hook weighs a hefty 4 1/2 lbs, with 3/4" bolt hole at 4 1/8" center to center. Most likely from a big truck or bus but not near the $$ of OEM hooks. $50 shipped Priority Medium Flat Rate USPS box. Money order, do not have Paypal.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
06-02-2020, 07:25 AM | #2 |
Re: Low Budget Alternative Tow Hooks
ttt low cost alternative for tow hooks
06-04-2020, 01:58 PM | #3 |
ttt for tow hooks
06-04-2020, 02:59 PM | #4 |
Proprietor of Dale's Corner
I mounted a set of these on the sides of my receiver hitch.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
06-04-2020, 10:52 PM | #5 |
I believe the rear tow hooks for our trucks are actually this configuration.
06-05-2020, 12:18 AM | #6 |
thank you gentlemen for the suggestions, I'll buy those from you sir, pm on it's way..
and just took this picture to show ya'll where I'm going to put 'em the hooks will match the ones up front just right
I started out with nothing - and I still have most of it |
06-05-2020, 08:15 AM | #7 | |
TOW HOOKS SOLD to Killer Bee. PM sent with payment info. Thanks for the purchase.
06-05-2020, 08:33 AM | #8 |
Exactly where I put them
06-05-2020, 09:08 AM | #9 |
Curious as to how you mounted them. Did you bolt them on or are they a welded on mounting? Either way I think would be very solid. A bit of engineering and the rear tow hooks solution is solved.
Thanks for posting your solution.
06-05-2020, 10:33 AM | #10 |
I bolted them.
06-22-2020, 04:37 PM | #11 |
tow hooks arrived today as advertised, thank you very much!
I did notice some numbers and markings on them, when I have the time, I'll post them in Pete's thread.. thanks again, they look like perfect match for the fronts!
06-22-2020, 07:30 PM | #12 |
Craig, glad your happy with them. Thanks again for the purchase.
