WTB: Ignition Key/Lock Cylinder (1973-1977).
Hey guys, I'm looking for an Ignition Key/Lock Cylinder for my 1976. The earlier version that has the tab you push in with a screwdriver when pulling out, not the lock retaining bolt kind used in the 1980s squarebody's. Mine is slightly damaged and turns sometimes without the cylinder turning with the nob. It also jams at times, and I can't start the truck. So looking for one in good shape, and with keys obviously. Let me know. Thanks.
1979 GMC Sierra 3/4 ton Camper Special 1976 Chevy Cheyenne 3/4 ton |
Moderator
![]() Join Date: Dec 2012
Re: WTB: Ignition Key/Lock Cylinder (1973-1977).
Try sending a PM to LockDoc!
![]() Join Date: Jul 2015
The number on the set from the link I provided above is 607893. If I had the time, I'd just return the ones I ordered because their markup is absolutely absurd. You can find the same set here for $30 cheaper.
https://www.internationalkeysupply.c...-ignition-lock |
![]() Join Date: May 2010
If you need it shipped to Canada you might be better off going with a bigger company they usually have better shipping rates.
Rock auto has it for $17.48 ACDELCO D1402B https://www.rockauto.com/en/catalog/...cylinder,10041 Here it is on Amazon. https://www.amazon.com/ACDelco-D1402.../dp/B000C9P2SY
It only has original paint once |
