Old 06-14-2020, 11:03 AM   #1
JFORRESTERSR
72 k5 speedo sleeve
Good day all
I have a leak at the speedo cable at the transfer case and everything seems to point to the sleeve. Anyone know where I can get one or the work around?
thanks
JFORRESTERSR is offline   Reply With Quote
Old 06-14-2020, 11:42 AM   #2
PDXk5
PDXk5's Avatar
Re: 72 k5 speedo sleeve
I just went through this on my rig. There are two different sizes (diameters) for the speed gear, so two different sleeves and gaskets that seal the speed gear to the sleeve. When I searched you could get a similar gasket seal at Fastenal but I ended up buying at Motor City K5.
https://www.motorcityk5.com/i-13102-...=category:9415
You also need an o-ring that fits around the sleeve and compresses the seal to the transfer case to seal sleeve to transfer case. I took my sleeve to the local plumbing store and found one that fit. I attached a photo. The sleeves don’t always come with the sleeve when you purchase them.
I’m assuming you have the sleeve but just need the seals. If not, the sleeve is speedy but available at Torque King.
https://torqueking.com/product/30091...chevy-and-gmc/
PDXk5 is offline   Reply With Quote
Old 06-14-2020, 03:35 PM   #3
JFORRESTERSR
that really makes me feel better I am going to take it apart this week and hopefully its just the oring
thanks for the help
