07-07-2020, 09:26 AM | #1 |
Lower steering column cover
I closed the door on my 84 C10 and heard a pop. I looked down and saw that one the lower steering column cover screws had finally worn out the plastic and popped. I know it's 36 year old plastic. Does anyone have one laying around or can you recommend a vendor that sells one that fits?
TIA! Kevin |
07-07-2020, 09:52 AM | #2 | |
Re: Lower steering column cover
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
07-07-2020, 11:19 AM | #3 |
I guess it has just been enlarged over the years. The head of the screw should still be outside of the cover, correct?
07-07-2020, 12:29 PM | #4 |
I believe it is the black abs glue can be used to fix the panel if you have some.
07-07-2020, 05:30 PM | #5 |
Hi well it it the black screws there just dash screws phillips head think there 1"-1/2" and they is a U nut that the screws in to. LMC sell them all or any body hardware supply shop will have them, Scrap yard.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
