Old 07-08-2020, 09:57 AM   #1
jkk
jkk's Avatar
Steering box and cooler installed
Installed a new steering box and cooler the cooler is a Little OEM piece for a ford truck
http://67-72chevytrucks.com/vboard/a...1&d=1594216593
http://67-72chevytrucks.com/vboard/a...1&d=1594216613
jkk is offline   Reply With Quote
Old 07-08-2020, 10:00 AM   #2
polishspy
Re: Steering box and cooler installed
im going to ask the silly question, why did you need a cooler for the PS fluid?
polishspy is offline   Reply With Quote
Old 07-08-2020, 10:31 AM   #3
jkk
jkk's Avatar
Can’t hurt they come OEMon many vehicles cooler can be better
Old 07-08-2020, 04:17 PM   #4
Pontiac1976
Pontiac1976's Avatar
Well are you running factory tires sizes, are you driving in heavy Traffic now and then.
This alone will make it better for the PS fluid to last longer make the pump last longer.
Because the temp of a PS system are hot any time you can take out heat out there is + to it.
Since you added the cooler you may want to add a filter for it too.
Nice job
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 07-10-2020, 09:51 AM   #5
Ziegelsteinfaust
The act of the field being whipped around by the pump, pressurized by the pump, and passing through the box all heat the fluid up. Add in under engine bay which is hot attached to a very warm engine.
It helps the seals last longer, and the pump work more evenly since the fluid won't thin out technically by heating up.
I am not sure when it becomes nesacary, but brand F was quite into them in the 3/4 ton and above rating.
Ziegelsteinfaust is offline   Reply With Quote
Old 07-10-2020, 10:16 AM   #6
jkk
jkk's Avatar
Yes correct the fluid temp was at 230F after driving on the highway no overdrive motor turning 2500 at 75 after cooler installation temp down to 190 F every bit helps same reason I run a trans cooler and a oil cooler with a 180 thermostat oil temp dropped from 240 F to 200F in the summer heat
Old 07-10-2020, 01:23 PM   #7
Ziegelsteinfaust
If my memory is correct when you start getting to 225*, and definitely all in by 250*. Seals start becoming hard due to breaking down from excessive heat atleast in transmissions.
So I may need to do the cooler myself in my Willy's. The brand F ttb frame i have it on has a simple one that leaked. I plan to add 35" rubber so it looks to be a wise investment for longevity. Or I can let it leak for brand f rust proofing the under carriage.
