07-18-2020, 12:16 PM | #1 |
DIY CST Chrome Interior Bedside Strips
This was buried in another thread of mine, but at the suggestion of a forum member, I'm breaking it out to make it easier to find.
I thought I'd share what I think is a pretty successful "hack" to create your own CST chrome interior bedside strips (the ones that hold the top of edge of the vinyl panels in place). Step 1: Order 2x of these Schluter Rondec 3/8 Stainless Steel bullnose tile edging. DO NOT TRY TO USE ALUMINUM! The AL ones are hard anodized and you will be unable to polish the rolled edges without a witness line. Step 2: Trim to length. Because the bed-rail is recessed you have to measure to the outer edge of the two S-curve profiles at either end of the bedrail. The final product is longer on the inboard side than the outboard side, so make sure you measure and trim to the longer inboard length. Step 3: Cut a rough profile. Cut a rounded taper from bottom to top, and a a slight taper from back to front (outboard to inboard). The outboard to inboard taper should match the S-curve profile of the recesses in the bedrail. Note, the front and rear S-curves are slightly different, for a perfect fit you'll want to measure and cut them specifically. Step 4: Roll the cut edge. I tried several approaches but ultimately just ended up using some stubby needle nose pliers to slightly roll the cut edges under. Step 5: Sand & Polish. The pliers will leave some pretty deep gouges, so you'll have to sand them smooth. Then polish the living hell out of the entirety of both pieces. Step 6: Rivet in place. Prior to riveting, I applied a half-width of some very thin 3M trim adhesive tape. This helps with mounting, but more importantly it prevents any buzzing between trim strip and the bedside. I used very small stainless steel rivets about every 10" to fasten the trim strips to the bedside. You could possibly use screws, but they would need VERY low-profile heads so that the vinyl panel's top edge can still slide up into the trip strip. Step 7: Install your CST panels and enjoy! I'm personally thrilled with the way these came out, and the whole thing cost ~$100 which is about 1/10th the price of tracking down the real thing, then getting them re-plated. But, I know for some folks they'll want the authentic parts, and more power to ya'! Just wanted to share this as an option. Last edited by harrij4; 07-18-2020 at 12:22 PM. |
07-18-2020, 12:17 PM | #2 |
Re: DIY CST Chrome Interior Bedside Strips
And, the finished product:
07-18-2020, 12:32 PM | #3 |
Looks good. Nice write-up. Thank you for sharing
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
07-18-2020, 01:04 PM | #4 |
What he said!
I already bought the strips because of your discussion. Probably be a year before I need them.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
07-18-2020, 03:24 PM | #5 |
This is a great alternative to the hard to find and expensive originals!
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858 |
07-19-2020, 10:11 AM | #6 | |
Posted via Mobile Device |
07-20-2020, 12:21 AM | #7 | |
01-10-2021, 12:50 AM | #8 |
Reposting it to the top!
01-10-2021, 04:02 PM | #9 |
I just ordeed the strips from HD. I was reminded when I saw your post on FB the other day. Thanks again for sharing.
01-10-2021, 07:59 PM | #10 |
This is great. Thanks for the write up.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
01-10-2021, 09:35 PM | #11 |
Perfect alternative
04-28-2022, 06:00 PM | #13 |
BlahBlahBlah
Thats really thinking out of the box, nice job. I work at Lowes and I see those all the time, I had no idea they were Blazer parts haha!
04-28-2022, 06:24 PM | #14 |
Just to add to this that these are reproduced. Not to take away from this option, but you can pick these up from Motor City k5.
https://www.motorcityk5.com/i-13858-...=category:9936
05-01-2022, 09:06 AM | #15 |
That worked great..was going to send mine out to be chromed for $825 thanks for the heads up.
05-01-2022, 10:05 AM | #16 |
I got another Blazer last month and didn't look to see if the chrome strips were there. I just went out and looked, wow they are present. It's a good feeling to find them just like when a found the spid in the console.
05-02-2022, 09:28 PM | #17 | |
05-02-2022, 11:04 PM | #18 |
I agree. I think these are made in the USA as well. Good to have these options for sure.
05-03-2022, 07:28 AM | #19 | |
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
