Trailer connector troubleshooting
2001 GMC Yukon. I am getting no voltage out of this right turn signal trailer connector. The rear right turn signal does work on the vehicle itself. Where do I look next?
![]() ![]() Join Date: Jul 2002
Re: Trailer connector troubleshooting
I would trce the trailer pigtail back to where it joins the main wiring loom for the rear lights. I think mine was right behind the license plate area on my 2002. Then inspect for damage to loom. I would imagine you might have to unwrap it and check at the solder joint. You can also check on the pigtail socket where the wire enters the socket.
Moderator
![]() Join Date: Oct 2008
On the 1999-2014 GM light trucks there's a junction block on the LH frame rail with four Delphi Aptive Metripak GT 280 connections.
Get out your back probes and Voltmeter or test light to check for juice at the connector on the J block. It'll look like this... The PDF in the link below is the General Motors Light Truck Upfitters guide for the T800 trucks. Page 79 is the J block plug placement guide. Pages 91-94 are the J-Block plug pinouts along with connector and terminal part numbers. https://www.gmupfitter.com/files/med...plications.pdf It's not impossible that the J-block is bad. Don't bother with the Dorman part get a used one.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 07-20-2020 at 06:13 PM. |
![]() Join Date: Jul 2015
There's a separate fuse inside the interior fuse panel for the trailer turn signals. After verifying that works, then check the in and out of the junction block as they are know to fail or have dirty connections and broken wires.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
