Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 07-20-2020, 12:44 PM   #1
sweetk30
sweetk30's Avatar
transmission output flange nut / socket ?
so i need to change the seal on the back of my spicer 5 speed in my 88 gmc 7000 truck . i have measured up the nut and cant find a socket the correct outside size to NOT bind up inside the flange body area .
anyone have any helpful hints other than the old hammer & chisel method i prefer NOT to do .
looks like a 2" or 2 1/16" maybe ? across the flat's .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 07-22-2020, 05:56 PM   #2
VictoriaHardware
VictoriaHardware's Avatar
Re: transmission output flange nut / socket ?
I once had to do a similar job. Only could find a 3/4" drive socket to fit the 1 3/4" nut but the OD was slightly too big to fit down in that pocket. I had to buy a new socket and then grind down the OD just enough to fit without making it too thin so the wall would crack. Fortunately it worked. In 30 years I have never used that socket for anything else.
VictoriaHardware is offline   Reply With Quote
Old 07-22-2020, 06:34 PM   #3
Bimus
Grinding down a socket just seams wrong but I have done it.
Bimus is offline   Reply With Quote
Old 07-22-2020, 06:50 PM   #4
sweetk30
sweetk30's Avatar
yep to us tool guys its BLASPHEMY
but you got to do it to get the job done sometimes .
