Old 08-03-2020, 07:40 PM   #1
daveshilling
daveshilling's Avatar
Flatout C4 IFS Brake Line Routing... How did you do yours?
Hey Gang, I'm about to tackle the front brake line routing from my frame-mounted Mustang Hydroboost, and with the boxed in sections and tight spaces with LS pans and steering racks, I'm trying to sort out the best/most practical approach for front brake line routing. Driver side should be pretty straightforward, but getting to the passenger side will be a chore.
Anyone care to share their approach?
daveshilling is offline   Reply With Quote
Old 08-04-2020, 11:16 PM   #2
svr
svr's Avatar
Re: Flatout C4 IFS Brake Line Routing... How did you do yours?
On mine the proportioning valve i used had 1 port for the rear and 2 for the front. I ran both fronts up the left side until the rear stock cross member. From there i ran the right side on the back of the cross member then forward behind the boxing i put in for the C4. There was a hole already in my stock frame that i put the ridged tube through. I made a tab to mount the stock brake hose to and put them together. Did basically the same On the left side. Not sure why i cant put up pics anymore but on my build page there should be some.
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
svr is offline   Reply With Quote
Old 08-05-2020, 12:57 PM   #3
daveshilling
Thanks for the input. I couldn't find any photos on your thread of the front line routing, but I've checked countless other times for various things since I'm building the same chassis, same booster (=
