08-05-2020, 12:37 PM | #1 |
Calculating Transmission plastic Gear
How to determine proper speedo gear?
Need to change out the transmission speedo cable drive gear. NP435 Just replaced the rear end to a 3:54 Eaton TruTrak and now speedo is off. Tire size is P255/75 R16
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
08-05-2020, 12:52 PM | #2 |
Re: Calculating Transmission plastic Gear
Check with the guys at transmissioncenter.net , they'll either have the correct gear or you'll need the ration adapter gearbox to correct your speedometer. They custom built one for me and its dead on.
https://transmissioncenter.net/?prod...edometer-gears
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
08-05-2020, 01:01 PM | #3 |
Thanks very much, Will Do.
08-05-2020, 01:14 PM | #4 |
laying low
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
08-05-2020, 01:25 PM | #5 |
Also need Color, or number of teeth on drive gear.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
08-05-2020, 06:03 PM | #6 |
By a whole set and mix and match until you get close enough to a GPS. I tried the calculators and asking others and in the end it was trial and error and close enough. Of course my speedo cable snapped a few weeks ago, so not its anyones guess how fast i am going
08-05-2020, 06:33 PM | #7 |
08-05-2020, 07:06 PM | #8 |
I did this and got it right on the second speedo gear I tried.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
08-05-2020, 08:50 PM | #9 |
08-05-2020, 11:33 PM | #10 |
laying low
ten
Mitch someone posted this a while back.
08-07-2020, 02:42 AM | #11 |
Wait a minute, if you have a NP435, they DO NOT use the colored plastic gears that a Hydra-Matic and most GM manual transmissions use. This is not a GM manufactured transmission. NP435's have a drive (transmission output shaft) worm gear and a corresponding metal driven pinion gear/cable adapter assembly that must be changed in pairs together to get the proper ratio. Don't bother looking, they are all obsolete and there were DOZENS of combinations. Best way to correct for an axle ratio change is to use a mechanical ratio adapter gearbox as MJN pointed out and leave the existing drive and driven gears alone. They are available from several vendors, you provide them with information like how fast does the speedometer say you are going when you are actually going 60 (easy to verify with GPS). That way you will even correct for whatever tire size you are using.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
08-07-2020, 10:23 PM | #12 |
Thanks very much, I have contacted https://transmissioncenter.net/?prod...edometer-gears
awaiting response.
09-25-2020, 11:47 AM | #13 | |
Do you know what vendors would carry a mechanical ratio adapter?
09-25-2020, 12:04 PM | #14 |
09-25-2020, 07:04 PM | #15 |
Contacted them, No help.
09-25-2020, 07:13 PM | #16 |
One like this.
https://transmissioncenter.net/shop/...ratio-adapter/ Or they don’t have one for your transmission. |
