08-28-2020, 03:35 PM | #1 |
Hole ID
What are the bumpy holes in front of the front bump stop brackets used for?
08-28-2020, 05:28 PM | #2 |
Carpe manana
Re: Hole ID
Maybe brake hose? Don't have mine to confirm at the moment.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
08-28-2020, 05:32 PM | #3 |
Re: Hole ID
When I disassembled it, the brake hose was in the hole to the rear of the bump stop. I don’t know if that was the correct place or not.
08-28-2020, 05:46 PM | #4 |
Carpe manana
Re: Hole ID
Could be correct I can check at home if no one else chimes in.
08-28-2020, 06:00 PM | #5 |
Re: Hole ID
Might have to ask a previous owner that question.
And I do believe my brake line is suppose to be down a hole Last edited by litebulblsc; 08-28-2020 at 06:45 PM. |
08-28-2020, 07:06 PM | #6 |
Re: Hole ID
My frame is a 69 and the axle is a 72. So maybe when It had drum brakes the hose came out in a different location?
08-28-2020, 07:28 PM | #7 |
Re: Hole ID
Mine is a '72 and yours does not have the same brake line hole mine has. So you may be on to something
08-28-2020, 08:15 PM | #8 |
Re: Hole ID
I have a 72 frame
Some progress is better then no progress |
08-28-2020, 08:19 PM | #9 |
Re: Hole ID
Some progress is better then no progress Last edited by Tmend; 08-28-2020 at 08:33 PM. |
08-29-2020, 09:29 PM | #10 | |
Re: Hole ID
My 72.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
08-30-2020, 10:27 AM | #11 |
Re: Hole ID
I converted a 70 to disc brakes and had to drill the hole in the frame for the brake hoses.
08-30-2020, 11:01 AM | #12 |
08-30-2020, 03:44 PM | #13 |
Re: Hole ID
Thanks for the replies. I wanted to confirm before I started making hard lines. To be honest there are a lot of frame holes that I can’t ID yet.
09-04-2020, 03:31 AM | #14 |
Re: Hole ID
Nice work, Hope to be there at the end of month .
